BIKELAND > FORUMS > ZX12R ZONE.com > Thread: OK I got this idea for the 12... NEW TOPIC NEW POLL POST REPLY
beansbaxter
posted September 06, 2004 08:16 AM
I was sippin my espresso yesterday, starin at my 12 like I always do, and then it struck me what Kawi did. Alright, just hear me out on this one but I do think it is possible...
If you look at the front left and right blinkers on the 12, they are spaced away from the edge of the plastics the same distance they are on the 10. The only difference, is the 10 makes the mounting point all the way flush with the outer edge, that way you can install cool Euro signals as such.
I hope I am explaining this alright, but why cant you just do the same cut in the front plastics of the 12. Where the stock blinkers are at would be the back of the triangular cutout, and it looks to me it would fit perfectly. Does that make sense?
Whatcha all think? And can it be done?
posted September 06, 2004 09:07 AM
it really is a crazy idea when you can have a small set of LP's fit in there and work perfect? but then again... you should try it and see. it shure would give you more of a turnsignal...
harryzx-12
posted September 06, 2004 12:12 PM
Beans - You been hittin the crack pipe....again?
beansbaxter
posted September 06, 2004 12:37 PM
Dang there is no crack pipe...I really seriously think that can be done. Dont you all think the 12 would look better with those cool euro turn signals.
If you look at the new 05 6R, it has the stock turn signals and they are set just as far back as the 12. But there is a clear outline where they can come out and the euros can go in.
If I was rich enough, I'd cut my own plastics to try it out...Dino? Ozzy? I need some backup...
posted September 06, 2004 06:44 PM
I have a spare junk side. let me see and if you send me a turn signal I will cut it out and take pix's of it. I believe it is the left side.
Ozzy
need guberment cheese
posted September 07, 2004 05:15 PM
If I had a euro signal assy I would check it out on the spare set of plastic I have.
0.22925901412964 seconds processing time
