kangpow
posted September 05, 2004 11:55 AM
Edited By: kangpow on 5 Sep 2004 12:56
PCIIIr Problem
Today I was riding my 03 ZX-12. It has a full Muzzys system an a PCIIIr. The bike started sounding like a V-Twin and missing real bad, then it would run good and then bad. I disconnected the PCIIIr and the bike runs fine. Anyone else have this problem???? The bike runs good with out the PCIIIr, can I keep riding it with out the PCIIIr ???? Dose anyone else run theirs without the PCIIIr ???
posted September 05, 2004 11:59 AM
check yer cable routing... sounds like you've crushed yer PC3 harness and killed it.. dont hook it back up..
kangpow
posted September 05, 2004 12:31 PM
I checked the cable, there is no sign of crushing, pinching or wear at all.
motorcycleboy
posted September 05, 2004 02:21 PM
Corrupted map possibly...
Hook your laptop up to the pc3r and view the map. If it has jibberish in any of the columns (?$#@ type junk) the map is toast.
I have seen this before - cause unknown.
kangpow
posted September 05, 2004 03:05 PM
If it is a corrupt map can I just reload it ?
zemmy
posted September 05, 2004 03:27 PM
I have had two pcIIIr's fail also, the second failure also sounded like a v-twin, probably because an injector was stuck open.
I personally think they are crap, if routing the wires were so frickin important would'nt you think the instructions would be better.
Sorry for the rant..
I've removed the pcIIIr and the bike is screaming just running a full muzzy exhaust, 17t front, k&n filters and the muzzy advancer set to 5 degrees.
kangpow
posted September 05, 2004 04:33 PM
How hard is it to install the Muzzy advancer ??? Where does it go ???
motorcycleboy
posted September 05, 2004 08:50 PM
quote: If it is a corrupt map can I just reload it ?
yes.
