BIKELAND > FORUMS > ZX12R ZONE.com > Thread: knocking 12 NEW TOPIC NEW POLL POST REPLY
NINJA12
posted September 01, 2004 11:12 AM
knocking 12
HELP.
I have a 12 motor that's knocking.
All bearings are good. All wrist pins are good.
no signs of excessive piston slap.
No signs of any damage anywhere.
Bike ran good until crashed, when restarted it was knocking.
Dealership tore it down, checked and reassembled but it's still knocking.
Now he thinks problem is in the transmission.
How likely is that? It's a hard knock like a rod.
P.S. this is the second 12 i've heard of like this.
Any suggestions?
frEEk
posted September 01, 2004 11:59 AM
does it only happen when you're moving or when you rev the engine in neutral too?
posted September 01, 2004 02:31 PM
Sounds like your dealer didn't "inspect" too carefully. If it's knocking, SOMETHING is hitting SOMETHING else and he didn't find it. What's the answer to frEEks question? What were the circumstances of the crash? Exterior damage, speed? etc.
ninja12
posted September 02, 2004 04:55 AM
I agree about the dealer and the hitting.
Knocks at idle, no need to rev or ride.
Guy ran off the road into a dirt field. He went down hard but no external engine damage, mostly plastic damage.
In all fairness the first engine i heard about belong to a racer mechanic that
has build many engines, from 50cc 2 strokes to high hp race engines.
I say this because i really don't expect it to be the ovious rod knock.
kawpower
Mr kawasaki 2 you!
posted September 02, 2004 05:07 AM
check the cam chain adjuster,
posted September 02, 2004 05:28 AM
how about something they probably did not check like the oil gear hitting the back of the clutch basket. if that clip comes undone it can happen easy, happend to a friend of mine.
psycho1122
posted September 02, 2004 06:15 AM
Also, In Re; to Mad Mike's Comment...That clip should be a mandatory replacement if removed AND when installed has to be indexed correctly.
NINJA12
posted September 02, 2004 07:03 AM
Thanks that what i'm looking for.
0.38211584091187 seconds processing time
