BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Tuned for mileage NEW TOPIC NEW POLL POST REPLY
dontwanna10
posted August 15, 2004 07:05 PM
Tuned for mileage
before you Flame me......Has anyone tuned their PC more for efficiency and not all out performance.My bike runs quite well but I drive 100mi round trip to work and get sick of filling up every day. I have a PCIIIusb and a Yosh pipe, The map is a Powercommander download from their site. BTW I can get quite a bit of soot out of the exhaust tip so it is probably a bit on the rich side, I am pulling a plug tonight to read it but just wondered first if I could lean out the Cells right around cruise on the fuel map for better mileage? Suppose I just need to pay for a custom Map.....
12r's forever
posted August 15, 2004 08:01 PM
YOu should get more than 100miles to a tank unless you're heavy handed on the throttle.
YOu could try leaning the mixture out at the desired throttle percentage see if you gain any more mpg.
Otherwise pump up your tires a few psi and keep your chain lubed well.
ZXLNT
posted August 15, 2004 08:51 PM
Is your bike geared down any???
dontwanna10
posted August 15, 2004 09:11 PM
No, gearing is stock, and it WILL go more than 100 Miles , maybe 120?, I am in the process of checking the Air filters and reading a plug. I will then try to get an accurate mileage count. Sorry I don't have all the info yet. I wish I had a four gas to check the emissions. My mustang has a Wideband set-up installed and I am considering installing it in the bike for tuning. I hate guessing.
12r's forever
ZXLNT
posted August 16, 2004 03:42 AM
I have 1270 motor and -1 on front. 28 mpg with no mapping at the moment. I need to get my EMS put back on...
n_pride
posted August 16, 2004 06:35 AM
I have a 2003 with the 1270 kit, full yosh and PCRIII. I drive 150 miles per day round trip. My gearing is 18/41. My spedo says 80-85 at 5000 rpm. The map is the standard from Dynojet for the Yosh system. No matter how slow I drive, I can't go the entire 150miles on one tank. I too love my 12, but it sucks on gas. You may be able to lean it out some with the PCIII or just remove it, but I think you still will burn more gas than you wish. I changed my gearing in the back from 46 to 41 for the purpose of better mileage. I can't give you specific figures, but I definately get at least 5-8 more miles per gallon keeping the revs under 6000rpm.
Hells Dark Lord
living life, and loving it.
posted August 16, 2004 10:44 AM
hell 150 Miles per tank is asking alot out of a stock 12...let alone your 1270......lol
dontwanna10
posted August 16, 2004 12:24 PM
I pulled a plug and it is very dark brown, at least it is not black but I think I can lean it out a bit, I have alot more experience with cars but can't I tune it so the plugs burn a light tan/brown or almost white.
12r's forever
posted August 16, 2004 05:04 PM
HDL.... I once went 180miles on a tank of gas. The fillup took 4.96 gallons.
I was running 18/45 gearing. THe Busa I was riding with only took 3.4 gallons for the same distance!!
Talk about heart palpatations.....lol
matt sterbator
Hiding in the bushes
posted August 16, 2004 05:10 PM
Heh, got 128miles on the 1287. Fuel light started blinking once we hit the Foothills. Put 4.89 gallons in it when we got to the store
0.26013398170471 seconds processing time
