BIKELAND > FORUMS > ZX12R ZONE.com > Thread: bear motorsport velocity stacks NEW TOPIC NEW POLL POST REPLY
10rmotor
posted August 11, 2004 03:42 PM
I'm doing some research on velocity stack lengths. I read that bear motorsport makes billet velocity stacks for the ZX12R, which gave about a 10 Hp increase. Are they short or long? What does the 12R come with stock? The 10R has two short in the center, and two long stacks on the outside, I assume due to packaging inside the airbox. If the airbox were wider, would all 4 be long or short?
posted August 11, 2004 04:08 PM
Touchy subject (Bear Motorsports). I can say with some degree of knowledge that The stacks do not make 10 Static (As read on the Dyno) HP in the ZX12R. :Rolleyes
Hells Dark Lord
living life, and loving it.
posted August 11, 2004 05:28 PM
its not touchy Vinnie....tell us about them, I am seriously considering a set for the 10.....and I would like info on how they work, what makes them work, what they are made out of, how they are made, where I can expect to see/feel the difference......you arent trying to sell them to us here, you are giving us technical information, which is what this forum is all about....
ZX12Girl
Adrenaline Junkie
posted August 11, 2004 06:02 PM
I heard that!!! Give up some of that knowledge stuck in that head of yours!!!
I do not understand the difference between long and short either!!!
BA
posted August 11, 2004 06:19 PM
Vince, if it doesn't offend you, and in hopes of filling in for you just a hair, I'll reply to some of this. You seem a tad reluctant.
I have a set of the Bear Stacks. As with most stacks (ie, Busa, GSXR1000, GSXR750,etc), they come in varying lengths. Usually referred to as long or short. Sorry, I do not know the exact lengths but small differences in height can make noticeable HP changes.
The ones I have are purple. I understand that another set from Bear Motorsports are Gold. Muzzy's sells a set as well.
I believe mine were in the $200 range.
Both also offer a set that are pre-drilled for NOS nozzles.
They appear to be made out of aluminum. They are very light, and look to be very well made. I'm really happy with the quality personally. (time will tell on the o-ring longevity. They help provide a good seal)
The short ones (if you use all 4) should increase your upper rpm HP. The "long" ones should help build up the low and mid range with potentially a very minor loss up top. (theory)
An interesting twist is to use a mixture of short and long for the best all around power curve. Lots of testing is needed to be sure of what you are doing there, though.
Check out this recent thread for a very interesting read on the subject. Keep in mind it's on a BIG 12R engine. (14R?)
http://bikeland.org/board/viewthread.php?FID=1&TID=13452
I've not been able to do back to back dyno comparisons but what I have seen from others' is that the stacks can give you *something* like 3hp alone, or up to 5hp AT PEAK with slightly more fuel.
Anyone can feel free to correct me on any of that, I'm just going off of memory.
For $200, you could probably spend it in another area for a better gain. But, if you were like me, and every little gizmo and trick and have a couple of C-notes to spare, well,....you know what I did.
BA
10rmotor
posted August 11, 2004 06:30 PM
In my 10R box, the long center velocity stacks (which are curved) are approximately 2 inches tall measured along the centerline. The short outer stacks are maybe 3/4 inches tall and straight. What are the stock velocity stacks like in the 12R?
The reason I'm asking is because I have the opportunity to build a larger airbox, and I have two sets of 10R stacks, so I'm trying to figure out if they all should be long or short for best top end.
crashtech
posted August 11, 2004 07:10 PM
Yea no kidding do tell, I have been thinking of getting a set before I have it mapped. Worth it or not is the question? Anyone got a set for sale?
matt sterbator
Hiding in the bushes
posted August 11, 2004 07:30 PM
I bought a used set from a guy on LAB. Great lookin pieces.
Got them for my old stock bike, ended up getting this bike and it didn't have stacks so I put them on here. I'm starting to think it's running leaner than when it was mapped, maybe because of the stacks.
Trip to SMTW might be in order.
Hells Dark Lord
posted August 12, 2004 02:54 AM
i am looking to get everything out of this ZX10 that I can, and keep the stock bore and stroke.....I will run a full exhaust, PCIII USB, ignitions advance, BMC race filters, Degree wheels for the stock cams, thinner head gasket, Bear stacks, and a trip to SMTW so Kevin can work his magic.....I am hopeing that this will get me up to about 175 at the wheel.....only time will tell...
posted August 12, 2004 04:02 AM
Not Speaking about the ZX10 Stacks and only speaking about the ZX12 Stacks and Only about "MY" Experience with them. The short stacks are 5 mm shorter than stock and the Long are 5 mm longer than stock 10 MM Difference between them. On average I got about 3 real HP on the Dyno with the Short and about 1.5 with the Long. There is a dip in torque with the short between 5 & 7K there is an increase in the same area with the long. This seems to result is quicker times in Drag Racing but no more speed. The Short ones seem to give about 3 to 6 MPH on top end at Maxton which would seem to indicate that they make a lot more HP than the Static results show. If you have a question about anything else send me an e-mail.
crashtech
posted August 12, 2004 03:37 PM
Sounds good to me I am in on the long ones. Anyone got a set for sale????????????? Thanks Vince it sounds like you got it figured out. I would think a little more torque would be very usable on the street in the type of riding I do. Not that many speed runs for me.
posted August 12, 2004 04:35 PM
Smart Man! Very few street riders are running 180 MPH!
crashtech
posted August 12, 2004 04:59 PM
I saw on the bear website that they list a "new" nos stack and a "bear" stack but not a short or long. Whitch one would be the "long" one. Thanks
I dont think you can really "map" the stacks with anything other than back to back runs at WOT and some sort of A/F meter.
Just like you cant really map an Akrapovic pipe at WOT on a dyno. The A/F is always skewed!!! (at best a guess)
crashtech
posted August 12, 2004 05:25 PM
All rite I have been on Muzzys site now and I am lost. They offer three choices. Vince help me out here. Whitch ones should I get and be happy with. Thanks in advance
posted August 13, 2004 04:57 AM
The NOS / Torque Stack is the "Long" Stack that you see on Bear's site. I do not know about the Muzzy? I think they offer a short, STD and long The STD is the one that is the same length as Stock!
posted August 13, 2004 05:05 AM
Yep!
Hells Dark Lord
posted August 13, 2004 12:45 PM
can someone post bear's web addy.....thanks...
posted August 13, 2004 03:55 PM
Nope!
crashtech
posted August 13, 2004 04:42 PM
Thanks Vince, I am going to look around for a couple of weeks and if I cant find any second hand I will order them from Bear. HDL I will e-mail you the link if I can. Going to hook up a laptop to it tomm. morning at the dealer and tweek the lower rpm fuel to try and soften the studdering at idle to 3000 and put some timing in it above 5000. hope it helps for the time being. Man it felt goon this morning at 55 degrees!
posted August 13, 2004 11:27 PM
http://www.bearracing.com/
Ra12r
posted August 14, 2004 04:45 AM
You know,,,,all this "sensitivity" about Bear racing is really a bit ummm.....immature. Personally, if I can swallow folks on this site feeling that the zx12 world rescue team is a "business" called Muzzy's. Then on this site, I feel we should be able to comment about whatever and whoever. All products sold have some element of hype. Some more than others, ie: 195 hp or 35 additional HP for adding an additional 70cc and cams redegreed by 1 freekin degree.,,,,,hahahaha Honestly, I bought the hype and was frustrated as hell until I grew up and did the math. Duh!!! "My people perish for the lack of knowledge". Is having an extra 70cc good? YES But, don't buy the HYPE buy the cc's.
All this sponser's are IMMUTABLE and others are the devil is crap!!! This same mindset definitely does exist on other sites as we all know, but isn't membership what motivates business's to buy advertising. Besides, if you really look at the issues between the sites it is VERY PETTY!!! ie: you copied my threads, waaaaa or you said something bad about me, waaaa or whatever!!!
Personally, this site and any of them are simply PURE ENTERTAINMENT,,,,well 80/20. The rest is straight lies, exaggerations or just plain self promotion ego postings discuised as truth.
Think about all of this if anyone actually reads............Y2K (credible engineer) already posted a long time ago that the flow of the stock injectors were greater than the needs of a 350 chevy making over 500hp. Do we even need any stacks???
Hells Dark Lord
posted August 14, 2004 06:21 AM
Hells Dark Lord
posted August 14, 2004 06:23 AM
thanks for the link, I dont see any 10 products on there....I like the anodized sprockets......
posted August 14, 2004 12:05 PM
Now you see what I already know, Bear has made nothing to Sell for the ZX10 and has only made 1 item that he is in the process of testing for the ZX10 and is not even sure if he is going to market it. The same as the taller 5th and 6th Transmission gears he made but never sold either. He has never sold anything that was not tested "Both" there and Over here and by several people and he is no where near that Point with anything for the ZX10 yet! Everybody already knows what he has for a ZX12R.
0.22946619987488 seconds processing time
