BIKELAND > FORUMS > ZX12R ZONE.com > Thread: shorter shock NEW TOPIC NEW POLL POST REPLY
keith
posted August 10, 2004 11:21 PM
shorter shock
Has anyone sourced an alternative shorter shock, say half an inch shorter, that will fit the 12R that will make it possible to lower the bike more than with the stock shock?
ZXLNT
posted August 10, 2004 11:46 PM
The tire hitting the inner fender or the fairing scraping the ground is the limiting factor on lowering. That can be done with stock shock and lowering links....
Hells Dark Lord
living life, and loving it.
posted August 12, 2004 03:00 AM
go witht eh adjustable turn buckle style links....they shuld get you plenty low enough, and you dont ahve to remove the fairing each time you want to raise or lower the bike....
keith
posted August 12, 2004 08:41 AM
I've cut the fairing off just below the wings and fitted a Sidewinder. The bike has an extended tail unit too so the wheel shouldnt be a problem. Keith
0.25692200660706 seconds processing time
