beansbaxter
posted August 10, 2004 12:49 AM
Swingarm differences
I know the swingarms are different from a 1st and 2nd gen 12. But will a swingarm from a 2nd gen 12 fit the 1st gen models ok? Is there any additional mods or will everything bolt up ok?
Just curious on the matter.
posted August 10, 2004 01:59 AM
Yes it will work...all years interchange. Only difference is the bracing up front.
ZXLNT
posted August 10, 2004 02:34 AM
Aren't the dogbones different lengths between years???
Hells Dark Lord
living life, and loving it.
posted August 10, 2004 03:16 AM
no...they are the same....
ZXLNT
posted August 10, 2004 03:34 AM
Otay..
osti33
posted August 10, 2004 04:30 AM
I am pretty sure the first and second generation dog bones are different lengths. I have two sets from Muzzy and they are definitely different lengths.
Part numbers below(copied and pasted from Muzzy's website).
M1200-SL 2000-2001 ZX-12 R Lowering links
0048-00001 2002-2003 ZX-12 R Lowering Links
posted August 10, 2004 04:51 AM
They would have to be. 2nd gen 12 had lower pivot point in the frame, as I recall...
posted August 10, 2004 01:50 PM
The 2002 and newer dogbones are slightly longer than the A1-2 models.
beansbaxter
posted August 10, 2004 01:54 PM
Crap...now the dog bones I got from Dino dont have part numbers...wonder which gen 12 they fit?
posted August 10, 2004 02:46 PM
Measure them against your stockers.... its easy enough. Then mark em with a sharpie!
bossman12r
posted August 10, 2004 03:40 PM
02-04 are the same lenth and 00-01 are the same.
Hells Dark Lord
posted August 12, 2004 02:59 AM
the ZX6/7/9/10/12 are all currently using the same stock length....if there is a difference between the A models and the B models its minimal.....just ook my adjustable links off the ZX12, and put them next to the stock bones on the 10, and they are exact...so i bolted them on.......hehehheh
