Gquinn
posted August 03, 2004 10:22 AM
Crank Balancer
Hey guys question on the crank balancer for anyone that has a manual. On my ZX11 you would start the motor cold and turn the balancer counter clockwise until it started making a whirring sound and then turn it back slightly until it stops. Is that the same procedure on the 12. Any help will be greatly appreciated.
slug
Out in search of my mind...
posted August 03, 2004 11:12 AM
"Crank Balancer"
and here i thought you were referring to some of the illustrious street "corner workers" on this site...
as for the real question, no earthly clue
posted August 03, 2004 12:58 PM
Maybe he means a timing rotor?? :confused:
posted August 03, 2004 01:28 PM
That's basically it. Just don't "tighten" it. What you are adjusting is the "lash" or clearance between the gear teeth on the balancer and the crank. There needs to be some but not too much.
Doug
Gquinn
posted August 03, 2004 02:06 PM
Thanks Doug, I new about the backlash just wanted to be sure it was counter clock wise like the book said on my 11. you can go either way but if you turn clockwise I belive you are at a different balance point.
