BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Things I've notice since dumping IE NEW TOPIC NEW POLL POST REPLY
posted August 01, 2004 10:08 AM
Disk cleanup no longer grinds to a halt due to gigabyte of temp internet files...
Pages load about twice as fast as before...
Battery lasts longer (much longer) because I'm not spinning the disk drive so much (see first note) so I can surf for a long time while on the battery.
canadamaxxer
posted August 01, 2004 10:39 AM
THe crappy thing about firefox that I've found so far is the warning you get if you use shortcuts to URL's from the desktop. I have a couple links setup as shortcuts and I always get an error message whenever I use them. Other than that, I really like the program, and love the tabs....
RAC4IT
Bergie
posted August 01, 2004 10:46 AM
Uhhh... You do realize you can configure the size of the temp internet files that IE stores? Sounds like the old I D 10 T error if you ask me, there's nothing wrong with IE.
Tools > Internet Options > Temporary Internet Files > Settings
luckycharm
posted August 01, 2004 10:52 AM
EEBKAC
(Error Exists Between Keyboard And Chair)
Everyone justs wants to ignorantly jump on the IE hating bandwagon.
posted August 01, 2004 11:05 AM
Yah, what does US-CERT know?
http://www.us-cert.gov/cas/techalerts/TA04-212A.html
Or Infoworld?
http://www.infoworld.com/article/04/07/16/29secadvise_1.html
Many many others...
luckycharm
posted August 01, 2004 11:11 AM        Edited By: luckycharm on 1 Aug 2004 12:12
Yes
slug
Out in search of my mind...
posted August 01, 2004 11:12 AM
i use firefox due to the pop-up blocking features.
another nice thing about mozilla is you can alter the number of threads/ports to open to webserver. on fast connection this makes huge difference in webpage display
just two small things that make life alittle better
the big one is the popups though. 0.0000 popups. but sites that rely on a real popup (say, bikeland and the IM window) can be unblocked and work normally.
the only complaint i have with firefox so far is that IE-specific java tags don't work exactly as expected (but that's why they are IE specific..
the 'hate IE bandwagon' is not all about ignorance, there are certain features that just workbetter on mozilla IMHO.
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
luckycharm
posted August 01, 2004 11:14 AM
slug, try the Google Toolbar in IE, I found it to work better than any Mozilla derivative.
DaveInDaytona
posted August 01, 2004 11:23 AM
They all have holes
http://www.kb.cert.org/vuls/id/927014
or even better
http://www.us-cert.gov/cas/bulletins/SB04-203.html
How does activex work in mozilla ?
DaytonaSportbikes Forum
slug
posted August 01, 2004 11:28 AM        Edited By: slug on 1 Aug 2004 12:35
lucky: don't use that anyway
dave: not sure on activex, know any sites that would work to test?
as far as the vulnerability in firefox goes,
type about:config in to address bar
scroll down to "network.protocol-handler.external.shell"
andmake sure it says 'false'
then close and life is good. (mine was already set to false)
deathpulse
posted August 01, 2004 04:08 PM
I keep getting this strange problem with FireFox - XPCOM:EVENT something or other. It seems to come up after I open up Firefox and browse for a bit. The way it happens is, I browse for a bit - then, nothing seems to downloadn (no pages, nothing) via firefox (or if I open up IE, IE doesn't workeither), so I reboot, and I get this message that XPCOM:EVENT something or other is locked - please terminate. I terminate and re-boot and all is well. Only happens when I use firefox. strange.
slug
posted August 01, 2004 05:13 PM
never seen it. using 0.9.2?
deathpulse
posted August 01, 2004 08:23 PM
yep - and I just rebuilt the machine too... upgraded to an SATA raid 0 array... hmm...
Ra12r
posted August 03, 2004 08:15 AM
How do I increase the "pinging" frequency when trying to download. I read somewhere that downloads speeds can increase if the information is requested more frequently?! Also, I read something about changing the need for file varification as a way to get more data transmitted?!
frEEk
posted August 03, 2004 10:49 AM
ra12r, i can only guess that they're talking about making more simultaneous requests. taking the statement "downloads speeds can increase if the information is requested more frequently" at face value, it would definitely be incorrect as u'd jsut be increasing the load on the server (which slows things down of course).
not realyl sure what file verification means. could be talking about client-side cache settings, or file integrity verification. neither would increase actual data transfer speeds. whereever you got that info from, they defintiely need to cough up some details to make any sense.
posted August 03, 2004 01:31 PM
Hey, Talk English when you're in this house, young man!
Ra12r
posted August 04, 2004 02:14 PM
Okay, my cumulative reading over time has me thinking that there are some parameter changes that one can make to IE in the system level that would increase the speeds. I have dial up and it is slower now at 56k than I was back in the day with 28.8k!!!
But I thought that if the packet verification parameter could be changed then more information could be recieved resulting in faster times for surfing....??
Is there any way to increase the efficiency of IE??
frEEk
posted August 05, 2004 01:01 AM
best thing u can do with such a slow connection (assuming your machine isnt ancient too) is make sure compression is enabled for those sites that support it and u could try an accelerator. there are alot of them out there and they're always advertising them. basically they just preload all teh links they can find while you read the current page. for something like this forum it may not be all that useful tho as there are too many links to preload. make sure your cache settings are not set to never cache.
oh, my isp was telling me how i could get something to increase the speed 5x for $5 a month extra. i half suspect it was jsut them implementing the aforementioned compression before passing the data thru my modem, but that's jsut a guess.
posted August 05, 2004 01:04 AM
They also do a lot of image reformatting...That saves a ton. Take a 24 bit image and render it down to 16 or 8 bit, etc...
Marcos Peguero
posted August 05, 2004 04:57 AM
Doug, at least its not only me that do not understand these guys.
  Ignore this member    Click here to visit Marcos Peguero's homepage.
Ra12r
posted August 07, 2004 03:43 AM
How do I set things to compress for all the web sites then?
BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Things I\'ve notice since dumping IE NEW TOPIC NEW POLL POST REPLY
0.25632405281067 seconds processing time
