BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Voltage Regulator NEW TOPIC NEW POLL POST REPLY
DaGoose
posted July 31, 2004 04:41 PM
Voltage Regulator
Anyone have any experience with them on a 00 12R? Mine seems to be leaking a gas/oil mix from one of the electrical connectors. Any ideas?
slug
Out in search of my mind...
posted July 31, 2004 05:26 PM
if i recall from previous posts, there is a problem with oil wicking up the lines from stator cover. a search of 'wiring AND harness AND oil' yielded some of these:
basic fixes seem to include a zip-tie at the stator end to restrict the flow, removal of stator cover to RTV the harness end, and the actual factory recall (have dealer do the recall)
http://www.bikeland.org/board/viewthread.php?FID=1&TID=12849
http://www.bikeland.org/board/viewthread.php?FID=1&TID=8409
http://www.bikeland.org/board/viewthread.php?FID=1&TID=7935
http://www.bikeland.org/board/viewthread.php?FID=1&TID=5732
http://www.bikeland.org/board/viewthread.php?FID=1&TID=3583
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
DaveInDaytona
posted July 31, 2004 06:16 PM
Good answer slug. We'll make a 12 rider out of you eventually.
Recall is the first thing to check. If you bought it new you probably got a notice. If it's a used one go to
http://www.buykawasaki.com/Default.asp?strContentURL=site/VIVehicleInformation/VIChooseVehicle.asp?intCatalogID=2&intParts=0
and enter your VIN to see if it still needs to be done. Also the 2000 had a recall on the fuel tank and the valve stem nuts. They all should be listed.
DaytonaSportbikes Forum
posted August 01, 2004 02:15 PM
Yah, what he said!
0.3120322227478 seconds processing time
