BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Preparation for the track NEW TOPIC NEW POLL POST REPLY
Marcos Peguero
posted July 30, 2004 11:24 AM
Since some of you go to the track in your zx12r.
I whant recomendatios, setup (180lbs), considerations.
because I whant to get to the track and prepare the zx12r for the action.
  Ignore this member    Click here to visit Marcos Peguero's homepage.
necro
My Grandma Is A Virgin
posted July 30, 2004 02:40 PM
I don't dare take mine to the track, but if I did, the first things I'd do is SS braided brake lines and racing tires.
Outlaw1
posted July 30, 2004 09:33 PM
Find a crashed 600cc street bike bike and put race bodywork on it. It will cost you less in the long run.
Leave the 12 at home on track days.
Lead, Follow, Or get the hell outta the way.
posted July 30, 2004 09:40 PM
Why??
He'd miss all the fun!
Just look at Harry. That muther fucker could eat some of those "track stars"... and still run faster lap times than a fully stripped race bike....hehe.
He's a hoot to watch!
He rides like Pacman...
posted July 30, 2004 09:42 PM
Marcus....
-180/55 or 190/55 rear tire
-braided brake lines
-check all your bolts and locktite the subframe ones!
necro
posted July 30, 2004 09:44 PM
Do you want to buy my racing 600?
Outlaw1
posted July 30, 2004 10:14 PM
How much? what year? what Brand?
Hells Dark Lord
living life, and loving it.
posted July 31, 2004 08:54 AM
bump
Marcos Peguero
posted August 02, 2004 05:50 AM
I laready have SS lines, full muzzy, stering damper, PC3r, raised the back, lower a but the front.
the guys that I go to the track day usualy have R6 and ducs.
The track is short so I dont need more power.
My problem is at the curves....
posted August 02, 2004 05:54 AM
Bike go like bullet, turn like bullet.
jonwright
posted August 02, 2004 06:24 AM
Good tires.
And secondly I would also make sure you had........good tires.
Personally I wouldn't go with a 180 - not enough lean angle. 190 for me, please. Ran out of tire once. Not good.
Dino
posted August 02, 2004 05:35 PM
The 208 (200 series )works just fine on the track. Sounds like your ready
just don't do what that Canuckian did at Spokane last week! His pretty, red '02 is REALLY ugly right now.
uh oh
slug
Out in search of my mind...
posted August 02, 2004 06:41 PM
dependingon track organization, you may need to do zero safety wire, or a buttload.
Sportbiketracktime.com requires no drilling/wiring. your tires need to be in 2/3 or better condition, brakes functional (in good shape) throttle spring-returns properly, and (all but novice class) no antifreeze. gotta run water or water/waterwetter.
Also tape mirrors (or remove) lights (or remove), headlight/taillight should be unplugged (to rpevent cooking tape on), signals taped (pr removed) speedo taped over
other organizations have different requirements.
as for the rider: good gear.
take a boatload of water. i drank an entire 24-pack of 16 oz water bottles at barber, in 1.5 days.
take some means of shading yourself (easy-up, tent etc) and stay out of hte sun as much as possible.
sunscreen if you are prone to burning
camera (GOTTA take pictures) If you are doing STT event, killboy does the photo shoots for them.
any spare parts you might have (clipon, barends, pegs, etc) (if you have the spares you won't need the spares)
fresh tires if yours are in less than perfect condition
hrmmm more as i think of them
best of all, just have fun!
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
Hells Dark Lord
posted August 03, 2004 11:42 AM
my choice of tires for the track on a 12 is a 120/70 SC2 front and a 190/55 SC3 rear(Supercorsas)....I would safety wire the oil drain blug and saftety tie the oil filter.....drain the anti freeze and replace it with water wetter and distilled water.....make sure ya have a clear windshield....and good safety gear......go slow at first and get the feel of the track and the bike, and gradually pick up speed over the course of several laps.....get the tires good and hot, and get the feel of the chassis.....it will tell you what its doing...just listen to it....
BA
posted August 03, 2004 01:32 PM
drain the anti freeze and replace it with water wetter and distilled water......
gradually pick up speed over the course of several laps and get the feel of the chassis.....it will tell you what its doing...
I've had my 12R around Mid-Ohio and Putnam Park, it's great fun!!!
You're pretty much on the right track, adding the high-lights from the quote above.
I think ya done right be raising the rear a little, and lowering the front just a little.
Pay attention to whether it turns in easily, or whether it wants to push wide on exits and you can make small adjustments accordingly. You probably will make small adjustments each time out.
There is some decent info in this thread at another site.
Hope this works:
http://www.sportbikes.com/wwwthreads/showflat.php?Cat=&Board=tech&Number=204680&Forum=tech&Words=suspension%20setup&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=204680&Search=true#Post204680
EastBayDave
posted August 06, 2004 05:43 AM
Raising the bike up for clearance should help...I drag the shit out of the left-side lower fairing when I get it way over...it's flat ruined...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
Marcos Peguero
posted August 06, 2004 10:40 AM
Thanks, I already have a muzzy lowering link in the short one to raise the back and the front is lowered .9mm.
Next time I will try to adjust the suspension to get better results.
And keeep a log of the changes made.
At the moment I feell the bike just slow at the turns, like the front is going to leave, I have a HPX in the front.
Hells Dark Lord
posted August 06, 2004 01:20 PM
the pilot HPX is your first problem......I FREAKING HATE THOSE TIRES....JMO
raise the rear and it will turn in quicker.....dont lower the front, the 12 already has limited ground clearance.......
0.22863292694092 seconds processing time
