BIKELAND > FORUMS > ZX12R ZONE.com > Thread: PC3R help NEW TOPIC NEW POLL POST REPLY
crashtech
posted July 26, 2004 02:16 PM
PC3R help
Hey guys. I was thinking of getting my 12 custom mapped and was wondering how much timing should be added and where (if I can get it better myself that would be cheaper). I know Rog and HDL have a Muzzy advancer for 4-4 1/2 degrees all the time. Should I tell them or put it in there myself or does anyone know of a map that would work well with timing and fuel already done. Does the timing added effect the fuel? I have a muzzy pipe and pc3r , clean air removed and K&N's. Thanks
Hells Dark Lord
living life, and loving it.
posted July 26, 2004 02:23 PM
Brett, a good shop will know how much advance to put in the map. They should build it to give you the smoothest throttle response possible...usually it will start with a little to no advance in the lower RPM's and build more advance in the higher RPM's....this will vary somewhat from bike to bike....just like the richness or leanness will vary in different throttle positions and different RPM's....and each bike is just a tad bit different......
Outlaw1
posted July 27, 2004 03:20 PM
I agree with Jim, Brett, The 12 stumbles so bad comming outta the hole, I would not just put 4 degrees across the entire range. It could make it worse.
Go for correct AF ratio frist and advance timming from there.
If you could get rid of the outta the hole stumble, It will make a huge difference. If you do Dyno take some cam 2 with you to add as well, Not to replace gas but as an addition to gas. Since your advancing timing a little boost will help.
Lead, Follow, Or get the hell outta the way.
Outlaw1
posted July 27, 2004 03:25 PM
I would run 89 octane to get AF in range. Once your AF is in safe range, add timing advance. And after you have it sorted out add about a half of gallon of cam 2 and run her one more time. I believe with timing advanced the cam 2 will help ya on the big end,
You need to sort everything out and have game plan before rolling it on dyno for tuning. Saves time and money.
0.26356410980225 seconds processing time
