BIKELAND > FORUMS > ZX12R ZONE.com > Thread: F-14 breaking the sound barrier NEW TOPIC NEW POLL POST REPLY
Widowmaker
posted July 25, 2004 08:41 AM
http://www.softlab.ece.ntua.gr/~sivann/pub/F14supersonic.mpeg
RAC4IT
Bergie
posted July 25, 2004 10:07 AM
damn that shit is cool!
Widowmaker
posted July 25, 2004 12:15 PM        Edited By: Widowmaker on 25 Jul 2004 17:11
F/A-18 Hornet breaking the sound barrier.
that B-52 is killer.
beansbaxter
posted July 25, 2004 12:33 PM
Wow that is cool...but why does all that stuff come out?
Widowmaker
posted July 25, 2004 12:43 PM        Edited By: Widowmaker on 25 Jul 2004 13:45
At sea level a plane must exceed 741 mph to break the sound barrier.
The change in pressure as the plane outruns all of the pressure and sound waves in front of it is heard on the ground as an explosion or sonic boom.
The pressure change condenses the water in the air as the jet passes these waves.
Widowmaker
posted July 25, 2004 12:58 PM
this is cool sound too.
http://www.cnn.com/TECH/9710/13/land.speed.record/speed.20.mov
deathpulse
posted July 25, 2004 01:18 PM
Don't tell me that BUFF up there above is breaking the sound barrier. That must be photo shopped. Same thing for the B-2.
matt sterbator
Hiding in the bushes
posted July 25, 2004 01:20 PM
Nope, just humid air.
Widowmaker
posted July 25, 2004 04:01 PM        Edited By: Widowmaker on 25 Jul 2004 17:12
It has to do with altitude and humidity being over the ocean.The B2> high subsonic speed, <331m/second cannot reach a sonic boom.
Then again the top speed is top secret.
(A Lockheed video)
beansbaxter
posted July 25, 2004 11:01 PM
As I understand it, the plane does not outrun the pressure and sound waves in front of it. The air is compressed by the leading edges of the plane. This "shockwave" propagates outward at the speed of sound. Below mach 1, the pressure wave acts on the air molecules in front of the plane so as move them away from the leading edges and cushions the transition. At and above mach 1, the leading edges impact on the air molecules directly. This causes an immense high-pressure region that is then heard as a sonic boom. The boom does not occur as a single event, it is a continuous phenomenon as long as the plane is supersonic. A ground observer will hear 2 booms, the second from the rear of the plane, as the high-pressure volumes pass by. The visible vortices are actually regions of low air pressure wherein water vapor is condensing. It is not necessary for the plane to exceed the speed of sound to generate vortices; it merely requires the negative pressure to be below the partial pressure of water. The vortices are usually generated from the trailing edges of the plane. Cavitations from a ship's propeller are due to a similar cause. Visible vortices are not altitude dependent but the negative pressure must be blow the surrounding partial pressure of water to cause them to occur.
diablodcielo
posted July 26, 2004 03:38 PM
I've heard a similar sound coming off a couple of TL1000s, they must break the sound barrier too cause when they let off the gas it sounds pretty loud, hell on some of them I've seen a puff of smoke,, maybe condensed air too,,,nahhh must be the raw fuel ,, sounds pretty funny though. This stuff of the planes is pretty neat, I had only heard about the sound popping when they break the sound barrier;but hadnt seen the cloud it made at the same time. Cool stuff.
Widowmaker
posted July 26, 2004 04:03 PM
TL1000 I got a buddy with one wow its slow.
zxfingyz
posted July 26, 2004 05:32 PM
When I was a kid there was an air guard unit (F-4's)I think up near great lakes in IL that used to get kicks by breaking the sound barrier on the Lake Michigan. Story goes that one day they were doing it and the sonic boom shattered the windows in some politicos summer home on the lake. They moved them all to Terre Haute Indiana the following year.
necro
My Grandma Is A Virgin
posted July 26, 2004 09:33 PM
I've seen that before. It's cool.
Marcos Peguero
posted July 27, 2004 10:25 AM
No Widow, you have a F... fast bike.
When I go to the track here (short one) in the straigths, the only bikes that can keep up with me are the GSX1000 full race superbikes. I hear all the bikes change gears and mine just finish 3erd and 4th till 10500 rpms and they are behind.
when I told them that I use 2 gears they where like. shit.....
  Ignore this member    Click here to visit Marcos Peguero's homepage.
0.25068092346191 seconds processing time
