BIKELAND > FORUMS > ZX12R ZONE.com > Thread: ZX12R Map NEW TOPIC NEW POLL POST REPLY
Billy Varner
posted July 17, 2004 12:20 AM
ZX12R Map
I have a 2000 ZX12R Mods are Akarpovic full system,kleen air removed,filters modded,pc3r.I paid Mph 250.00 dollars to make me a custom map. Bike never ran right almost like someone jetted a pair of carb's that was not right.The first 3 gears you crack the throttle get out the gas go to get back in the gas bike would fall on it face then take off.The work was done last year.So i had another shop by the name of Canton Cycle Specialties make me a custom map They charged almost 200.00 witch was done last year.Took the bike to the track popping& backfiring out the pipe.Contacted Dynojet they had me send the pc3r so they could check it out recieved a call from dynojet saying the map was not going to work.They found no Problem with the pc3r but would send me a new one with another1year warranty.Took bike to the track 4 weeks ago with the stock ecm plugged in a guy name Chris went 9s@143.85 his first past.I live in Akron Ohio if anybody running the same mods as me could help me with a map please help me out Thank's BillyZX12R
deathpulse
posted July 17, 2004 08:06 AM
Hey Billy, check out the other zx-12 site (www.zx-12r.org). They have some nice custom maps posted under here
http://www.zx-12r.org/Motorcycle_info/ZX12R_Performance_upgrades_fuel_timing.htm
BA
posted July 17, 2004 08:30 AM
I agree with Deathpulse. You'll find one there that is from someone else with similar mods as you have.
Those two shops don't sound like they did you any favors at all. I've had 3 different pipes on my 2000 12R and have never had the problems that you've described, I feel really bad for ya!
Sounds like Dynojet was good to ya, it's good to hear that.
Did you get a dyno sheet from either shop with those maps? If so, did it show the A/F ratio at the bottem of the sheet??
The 00-01 12R need major adjustments at 2000-3000rpm, and also again at 5000. You should have big numbers in those boxes of the map. (all throttle positions)
My 3 pipes were the Muzzy, an HMF and a step Hindle, just PM me if you want a copy for comparison.
Hells Dark Lord
living life, and loving it.
posted July 19, 2004 05:11 AM
there are cracks everywhere....Was at a bike rally this weekend and wanted to Dyno my bike to see if I picked up any HP from the mods that Roger did to the bike during its build up....The guy never strapped the bike to the dyno in the rear...he made the first pull and the rear tire was smoking on the drum the whole time......he made pull 2 and the smae thing hap-pened......he went to make pull 3 and I just told him to unstrap it and take it off.....
The bike was Dynoed in Daytona@180 hp, and Kevin at SMW in Jacksonville made the map in it and got 180.1 HP outo f it then, this guy on a DJ250 got 169 HP.....i was laughing at him as he pulled it off the dyno, he said its one of the top 10 bikes that he has had on the dyno, I just smiled and told him it was because he deals with Harleys.....
0.2299280166626 seconds processing time
