BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Bear stacks on strokers: fit issues????? NEW TOPIC NEW POLL POST REPLY
posted July 05, 2004 10:49 PM
Am I the only one having problems getting a perfect fit of Bear (and Muzzy???) stacks onto the TB's???
When I CAREFULLY install/inspect the stacks onto the TB's, i see less than a perfect mating where the stacks meet the TB's, i.e. a bit of a crack on some of them. I used gasket material to "shim" a couple of the stacks and finally got a pretty good fit but not perfect.
I'm thinking that that the .080 base spacer used with strokers has pushed the TB's up??????
Anyone else????
catman12
posted July 05, 2004 11:08 PM
Yes I have the same problem, this because of the base spacer.
// Mikael
  Ignore this member    Click here to visit catman12's homepage.
posted July 06, 2004 05:42 AM
catman,
what did you do to get a seamless fit???
posted July 06, 2004 05:46 AM
Saw that myself. If I remember right, we milled the stacks.
posted July 06, 2004 07:13 AM
swft,
thx for the experience. I am thinking about doing the same thing once I determine which set up is best for 1/4 mi. It SEEMS like a 2+2 combo is best w/longs in the middle, but I wanna see what happens at the track.
thx again
EastBayDave
posted July 06, 2004 05:42 PM
pics pics!
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
osti33
posted July 06, 2004 06:38 PM
Entropy,
Do you have picures?
I have a stroker motor and the Muzzy nitrous stacks and I didn't notice any fit issues.
I'm not sure what you mean by " a bit of a crack on some of them "
posted July 06, 2004 11:03 PM
no pix, but after tightening down the stacks, look down the bore of the stack/TB and where the stack meets the TB I don't get a perfect fit on all 4. I get a bit of a crack at the join. Not a lot.
Hmmmmmm..... ????
posted July 07, 2004 05:13 AM
Entropy, would a "Better" word for this be "Space"? Crack sounds like something broken?
johnnycheese
posted July 07, 2004 05:54 PM
You said crack and live in DC
LMAO
Nothing but love Vince
posted July 08, 2004 08:24 AM        Edited By: dougmeyer on 8 Jul 2004 09:26
Since the engine height (and then of course, throttle body height) varies with engine position in relation to the frame (and there is quite a bit here) and the cylinder height (varies with stroke), the portion of the stack that fits into the TB needs to be short enough to accomadate the "tallest" engine config. If not, then the stacks need to be shortened. The engagement of the o-ringed portion of the (Muzzy) stack is sufficient to provide a seal with the shortest possible height. As long as the o-rings seal, there is no functional impact on the length of the portion that sticks into the TB. Yes, that means that I'm saying that the "interruption" in the smooth I.D. of the stack/TB bore is not measurably relevant. (Which is something I said repeatedly back when some (Ted G) were trying to find the "magic bullet" causing the fictional and much loathed restriction in the 2000 ZX-12.
Doug
posted July 08, 2004 09:45 AM
Doug,
Thanks much for weighing in on this one.
Since the space/gap/crevice/interruption makes no difference than I am home free.!!!!
posted July 08, 2004 10:32 AM
"CRACK"
posted July 08, 2004 11:18 AM
gap = arroyo, chasm, cleft, clough, clove, gorge, gulch
crack = chink, cleft, fissure, rift, rima, rimation, rime, split, rent; discontinuity, interstice, interval; cranny, niche; crevasse, crevice
posted July 08, 2004 11:47 AM
Cervice, I like that one
posted July 08, 2004 12:29 PM
cleft... starts ME thinking...
0.63811898231506 seconds processing time
