BA
posted July 05, 2004 01:15 PM
Block-off plates vs PCV hook-up
I was curious what everyone else is doing in this situation...
I've always ran my PCV valve (just above & right of front sprocket cover) to the Reed Valve's.
Now I've been given these chrome block-off plates and I'm not sure if I want them. If I use them, where do I run my PCV valve hose too?
What are the rest of you doing with your PCV???
posted July 05, 2004 03:55 PM
I went to the local auto parts with the large hose and they found me a an airconditioning rubber plug which was the same diameter and thats what I used to close the hole to the frame airbox, its upen on one end and closed on the other...The small vacuum hose I used a mikuni jet to plug it...The entire valve assembly is removed...
BA
posted July 05, 2004 06:26 PM
I had done similar stuff as you did, but where have you ran the PCV to? Is there nothing connected to it at all now?
Hells Dark Lord
living life, and loving it.
posted July 06, 2004 02:38 AM
Roger just pulled all that crap off my 02 that he is working on. There is a whole box of shit that he took off it......all the unnecessary stuff....he plugged it all off and cleaned it all up......
