BIKELAND > FORUMS > ZX12R ZONE.com > Thread: beware, guess i found? NEW TOPIC NEW POLL POST REPLY
lubricity
posted January 19, 2002 12:55 PM        Edited By: lubricity on 19 Jan 2002 15:06
BEWARE, Guess What I found?
I'm doing my suspension today. Replace the shock all goes well. Then I remove the forks. I drain the rt side out, nice yellow fluid. I drain the lf side. A Grey slurry of metal pours out. F%$#@.
Rich
a poor 12 owner
  Ignore this member    Click here to visit lubricity's homepage.
12RPilot
posted January 19, 2002 01:38 PM
You mean the forks?
NESBA #209
ZXtra
posted January 19, 2002 01:45 PM
Re: Fork oil change...
Lube...I hate when you find things like that. At least you have it off the bike so it can be taken apart and checked.
I've read that there are handling benefits to be gained by changing your fork oil after the first year. The oil apparently becomes contaminated from initial wear. After the first year, the amount of wear lessens. -ZXtra
lubricity
posted January 19, 2002 03:10 PM
I bought the Race Tech gold valve and springs for my weight. And had them rebuild the rear shock. So we'll see.
rich
a poor 12 owner
0.24678611755371 seconds processing time
