ddpete3
posted January 18, 2002 04:27 PM
Tire plug
Just got a tire plug put in my rear tire...had a staple in it....what's your take on them?
VINCE12
Designated Drinker.
posted January 18, 2002 06:46 PM
I think I'd have gone with a patch!!Plugs seem to give up after a while!!!
2012 Metallic Spark Black ZX14R
12RPilot
posted January 18, 2002 07:30 PM
Alot of people will abhore a repair of any kind. Most will relate some story they heard of a plug or patch failing at high speed. I work in a tire factory and know a bit about tire construction and operation. I would have no problem using a properly patched tire. I am a little more leary of some types of plugs but not for an objective reason. I could just see an improper plug job failing easier. I can't imagine a good patch failing. In short, we roll the dice every day concerning safety. What are you comfortable with?
NESBA #209
ddpete3
posted January 18, 2002 10:07 PM
They did the plug from the inside.
I figure I can keep it in during the break in period...only got 150 miles on it now...I figure I won't be going crazy till after then and then I will put on a new tire.
VINCE12
Designated Drinker.
posted January 19, 2002 04:30 AM
Find out if it was what is called a BOOT plug,combination plug and patch,if so I think you would be safe!!
12RPilot
posted January 19, 2002 05:26 AM
It would be cool to see one of the rags do a test with different repairs and then run them hard on a dyno for a gazillion miles.
NESBA #209
ddpete3
posted January 19, 2002 01:27 PM
they called it a mushroom plug...goes on like a patch and they pull it through...there is a small piece of rubber sticking through that the guy said would go away in about 25 miles.
mattie_k
hill-billy!
posted January 19, 2002 02:41 PM
I got a drywall screw in my brand spanking new D207 a few years ago. Took it to burnaby kawasaki and they plugged it in about five minutes. Never had any problems like it coming out or losing pressure, it lasted fine even with high speed running. Make sure that the person who repairs your tire knows what he's doing!
God is an imaginary friend for grown-ups.
redelk
Please... speak to the hand.
posted January 20, 2002 06:36 PM
Question for 12RPilot
I have a slit that is approximatly 5/8" long in my rear Pilot Sport. It is in the middle of the tire and runs up and down (instead of left to right). The slit is half on the tire surface and half in a tread groove, but only goes halfway across the groove. It appears that the part of the slit on the tire surface goes all the way through, just like the part of the slit that is in the groove.
My question is, because it is a slit instead of a puncture, is it unsafe to consider using a patch. I have already put another tire on, but this tire with the slit only had about 600 miles on it.
My fear is that some of the belts' cords have been cut to the point where any use of this tire would be dangerous. My thinking is that a puncture (like a nail) might just push the belt's cords apart, but not really affect their integrity like a slit's actual cutting of the cords. Is this logical?
Even though the slit is almost paper thin and is well under 1" in length, I'm thinking the possible damage to the belts could cause serious problems when the tire is under the stresses of heat and speed. Comments (without taking any "liability")?
-Ernest Hemingway
Scooter
posted January 20, 2002 08:15 PM
Sounds like time for a burnout photo shoot.
"Growing old is inevitable, growing up is optional."
EastBayDave
posted January 21, 2002 08:23 AM
quote: Sounds like time for a burnout photo shoot.
I agree. I've never liked plugs even tho I've installed hundreds back when I was a young-ass gas pump jockey. I just think my life & the Big Ninja are not worth risking at high speeds. Like mentioned, run it during break-in, then change it or do a BIG burnout -before- attempting high speed runs.
I won't run a plug at ultra-high speeds. Maybe ok at slower speeds, but is a $130 tire worth my life? No way...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
12RPilot
posted January 21, 2002 03:38 PM
Redelk...
I gotta agree with you for the very reasons you stated. Punctures are one thing, splits and tears......nyet!
NESBA #209
TedG
posted January 21, 2002 08:34 PM
I have a plug gun that injects a mushroom shaped plug(1/2" head, 3/8" stem) into a small hole. I did one one on a fairly new Michelin. I wore the tire out and when I dismounted the tire I carefully checked the plug it took a pair of pliers to pull on the plug and I had to tear it to shreads to get it out, and that was from the inside where the head of the mushroom was. As for a high speed failure, well I have had tires go flat at extreme speeds and you don't even know anything happened until about 70 mph where things feel squirrly at 50 things get funky. I did a small calculation and for each pound of tire, at 200 mph there is over 2000 lbs of centrifigal force on a 17" tire. In other words that tire is solid, air or no. They don't work on rips, but a small hole, I'll take the plug anyday, because it fills the hole.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
redelk
posted January 21, 2002 09:14 PM
I figured so
After thinkin' about the possibilities of what could happen with a "patched slit" (NO GYN jokes, please), I wouldn't even use it for a smokin' burn-out photo shoot. With as few miles this tire has on it, it'd take too long to wear down. Odds are, the patch or the belts would let go first and when they do, I'll have more then I could handle.
-Ernest Hemingway
RAC4IT
Bergie
posted January 21, 2002 10:01 PM
I say dont be scared. My friend Scott picked up a nail at Maxton last October. We plugged it with a $5 Walmart kit, made some shakedown passes ~100mph everything was fine so he ran all day Sunday 150 mph on his nitrous assisted CBR600 with no tire problems. Plugs? I would use one for street riding no doubt. Top speed? Well, my bike is faster than his so I would probably question it above 150 mph..
EastBayDave
posted January 22, 2002 06:38 AM
well call me yellow if you like...but:
falling off over 100mph is something you never forget...
about the 10th tumble I was saying to myself "this has gotta end soon..."
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
