Marcos Peguero
posted June 21, 2004 04:39 AM
Batery charger
Since I irde every 2 weeks and the battery is like 4years old. I disconect the battery and put a charger in the nigth before.
Do I have to disconect the battery necesarily?
Does that makes the PCIIIr lose its mapping?
Any help is apreciated.
Otis
Captain Kickstand
posted June 21, 2004 05:11 AM
Just use your jumper cable, red to the cable and black to a footpeg. Disconnecting the battery every time would be a pain in the ass. Or, why don't you just buy a new battery?
Otis
Captain Kickstand
And the PC won't loose it's mapping if the battery is unplugged.
Marcos Peguero
posted June 21, 2004 05:27 AM
The problem is that the bike has those expensive bulbs that the last owner put in to it and it uses a lot of power from the batery. Now I only use one lamp for day and 2 for the nigth and usualy let it run W/o any a little so it charges the battery.
The jumper one is the one that goes from the positive to the 10mm nut in the box?
I thoung that if you connect the charger from there the bike will whant to start!
posted June 21, 2004 06:17 AM
The cable he's talking about is the jumper cable that was supplied with the bike. Most guys toss it. Go get a battery tender, and use the quick disconnect plug off it.
Otis
Captain Kickstand
posted June 21, 2004 06:35 AM
No the jumper is a totally separate cable. It came on the bike, do you still have it?
It seems to me Marcos you'd be better off dumping those other bulbs and get a new set of stock bulbs, they work fine.
Marcos Peguero
posted June 21, 2004 07:00 AM
I have a tender but it does not have the plug off thing.
Can I connect the tender to the + 10mm nut and the - to the brake pedal???
posted June 21, 2004 09:44 AM
No, the 10mm nut is where the cable to the starter is connected. Connect the tender to the battery terminals.
Marcos Peguero
posted June 21, 2004 11:07 AM
That nut also connects to the + of the battery...
Forgive my ignorance in electrical stuff.
I cheated on the univ.
Marcos Peguero
posted June 28, 2004 06:09 AM
Otis, you are rigth, I was beating a dead horse.
The battery died, shit Im so full of s... sometimes, I should have planned, a friend lend me a YTX12 BS (smaller) to make this weekend trip.
Is there a problem (electrical) if I use a YTX12???, I did not noticed any diference with the YTX14.
