BIKELAND > FORUMS > ZX12R ZONE.com > Thread: my problem is solved, mostly. NEW TOPIC NEW POLL POST REPLY
Otis
Captain Kickstand
posted June 21, 2004 04:06 AM        Edited By: Otis on 21 Jun 2004 05:09
My problem is solved, mostly.
Well, I went to check the plugs and quickly noticed that the #1 cylinder's stick coil was loose. Humm, what the hell, pulled the coil out and there was a bunch of white gunk on the bottom of it, pulled the plug out and it was soaked with fuel and some other white shit. Also, I pulled the rubber boot off the bottom of the stick coil and inspected the hole that goes on top of the plug and it was rusted out pretty good. Very strange indeed. I pulled the other plugs and they were OK but #4 was a little wet with fuel too. So I replaced the #1 plug cleaned all the plugs and coils. I had already pulled the battery out to "reset" the ecu so I put that back in, plugged the PC back in and fired it up. BAM all four cyliders were firing again. THANK GOD! I left all the bodywork off it and went for a 40 miles ride and it runs soooo much better but it still seems to not be 100% and the exhaust note sounded deeper, a little different. So I went home and pulled the plugs again and they all look good. I called Roger and he wasn't picking up (The bastard was riding in the mountains with the Turbo group. ) He called me back the next day and I described what was going on we ran through all the scenarios of how theis may have happened and what to do now. So this morning I am going to order a new set of plugs, just for piece of mind and I am going to oder a new stick coil to replace the one that has rust in it. I tried to clean it up as much as I could but didn't have anything small enough to get in there, plus if there was a bunch of moisture in there, it's best to get a new one. We are hoping that with new plugs, and a new coil the motor will get to where it was. We also think that what I am hearing from the exhaust may sound different to me because all the bodywork was off the bike and I am hearing more of the motor sound than the exhaust sound. Don't know if that is true or not but we'll see. At any rate, the main problem is solved and thankfully was not a major motor health issue. I want to thank Roger for all his advice and time spent with me on the phone and of course all your advice too.
FYI Roger also told me Brett got a smoking deal on a 2001 Silver ZX-12R fully "loaded" in immaculate condidtion and he's happy as a pig in shit. Good deal Brent!!
Ninjaman12R
as a Deal's Gap tour guide.
posted June 21, 2004 05:11 AM
Do you think that you didn't put the stick coil back on very good when you changed plugs? Then when we did all the riding in the rain enough moisture found its' way in there to cause the corrosion??? Sounds possible eh?
Otis
Captain Kickstand
posted June 21, 2004 05:24 AM
I think that's what happened. When I changed the plugs and did the valve adjustment I must not have pushed that stick coil all the way down. It must have been fine for the trip and for some reason just decided to come all the way off therefore no spark and fuel build up in the cyclider. As far as the moisture I don't think it was the rain while riding down there as much and the unbelievable storm I drove through coming home. I drove at about 5-10 mph for several miles when I hit Michigan and it was raing so hard most cars were off on the side of the road waiting it out. At any rate at least it's sorted out now. I'll let you know how the new plugs and stick coil turns out.
posted June 21, 2004 06:45 AM
It is easy to miss getting them all of the way down! I put Dielectric Grease (However you spell it) in the cap and around the seal to ease the in and out ans seal off the water. Funny when I was reading this, my newest problem is #1 also and I checked my Stick Coils also to measure the Ohms and when they were all the same, then I went on to something else (I had done) the Injectors!
Otis
Captain Kickstand
posted June 21, 2004 06:50 AM
Vinnie, Roger mentioned the Dielectric Grease too. I am going to pick some up today.
jonwright
posted June 21, 2004 07:00 AM
Well, glad to hear it muh man.
posted June 21, 2004 10:02 AM
Buy a nice size tube. Use it for all electrical connections, Light Bulb sockets all spark plug wires and all electrical connections what may ever see water of any kind!
your car is slow
Fuck Nitrous...Got Boost?
posted June 21, 2004 10:11 AM
not for use on skin otis
Do not taunt happy fun ball!
Otis
Captain Kickstand
posted June 21, 2004 10:20 AM
DOH!!!!!
Hells Dark Lord
living life, and loving it.
posted June 21, 2004 03:53 PM
good deal Chirs, I got your message today on my way home, I am sorry I didnt get it earlier bro....I was up in Gladwin, about and hour north of Saaginaw, for my brothers graduation...I didnt get hardly any riding in.....Kelly and I did ride the old mans Elctra Glide Classic for about 40 miles. We are thinking about buying a big dresser, prolly a Wing.....the Harley dont have enough umph to go much past 90 with the both of us on it....lol
Otis
Captain Kickstand
posted June 22, 2004 03:04 AM
Ya bastage, at least we could have hooked up for lunch or something on your way through or back.
Hells Dark Lord
posted June 22, 2004 12:36 PM
I hear ya bro, next time definately.....I usually go back and forth along I-69, not up 75......I am not sure exactally where you are over there, but I assume its closer to Detroit......
Otis
Captain Kickstand
posted June 23, 2004 03:05 AM
75 is closer to Detroit but it's not like I can't jump in the truck and drive an hour to meet a brother and his wife for lunch.
Hells Dark Lord
posted June 23, 2004 04:32 AM
amen brother....we will hook that up the next time I go up there.......
My next trip is gonna be to Lil Sturgis here in July, then my double track day down in GA in August.....
ynot
Naaaaarf
posted June 23, 2004 05:02 AM
You couldn't get those small hands of yours in there Glad to hear you got it back running.
But Brain... Where are we going to get enough Caramel and a Cherry big enough to cover the Alps?
0.22695684432983 seconds processing time
