BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Latest Problem! NEW TOPIC NEW POLL POST REPLY
posted June 20, 2004 08:10 PM
Latest Problem!
AFter finally resolving the clutch problem, I started on the ratty running around 4 to 5,000 RPMS! My first thought was maybe I miss aligned something when installing the cams. I checked and everything was perfect. Then I pulled the new plugs to see that #1 cylinder was not running as well as the others. I had already checked the throttle body sync and it is almost perfect (Same line on every gauge). I then switched the plugs and the same thing. I checked the compression and the lowest cylinder was 208 and the highest was 216. the #1 cylinder was 215 PSI Cranking pressure. Next I checked the resistance on the stick coils and they were all 1.11 Ohms. I hooked them all up and installed the plugs and they all fired the same. I also disconnected the PC3r and it ran worse. SO I am down to the #1 Injector or the ECU?
posted June 20, 2004 11:07 PM
maybe it just needs some DJ250 mapping??? You are at a lower than stock CR????
posted June 21, 2004 03:42 AM        Edited By: VincentHill on 21 Jun 2004 10:03
Ent, the expression "We have met the enemy and he is us" applies here. After thinking what / how this could happen, I know I messed it up. When I originally tried to start the engine, I turned the key on and off a few times to get the fuel system charged but it still would not start and run well. So in all of my hurry, I decided that maybe I could back fill the system by switching the fuel lines. When I changed them back the bike started and ran OK. The reason I do not think mapping will cure this is the fact that I put in new plugs and #1 cylinder darkened the plug where the others were closer to white! When I switched them around, the same cylinder was dark!
Yes, the compression Ratio is lower and leaning it out did make it run better but did not change the cylinder problem.
Right now, I think my fastest cure will be to get a set of used Throttle Bodies complete and change them. Find and Fix what ever is wrong later "IF" changing and injector does not cure it!
Just looked on the for sale area and someone says they have the Throttle Bodies for $250. I am buying them today if he replies!
ninja12
posted June 21, 2004 10:01 AM
some on ebay right now!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=34284&item=2482412335&rd=1
posted June 21, 2004 10:23 AM
Hey Vince you have mail.
MM
posted June 21, 2004 10:29 AM
MM You read my mind, I was getting ready to send you a message about the person you know has a set for a 2001. Now I will read my mail to see if I know what he is writing about!
Marcos Peguero
posted June 21, 2004 11:09 AM
I dont understand. did you broke the TB????
Maybe you need to clean them.
A friend of mine buys canned thinner and cleans them.
  Ignore this member    Click here to visit Marcos Peguero's homepage.
posted June 21, 2004 12:00 PM
I think the reverse pressure may have done damage!
harryzx-12
posted June 21, 2004 12:53 PM
Vincent ,any news on the shipment from Bear?
posted June 21, 2004 01:10 PM
NO. Remember Rickey Gadson is over there from the 15th of June for 2 weeks and remember, I did not speak to him about this until May 27, 2004. So I am hoping that he shipped before things got too Hectic and I know I postal shippment "I" Sent to him took 2 months! (I had really given up that he was ever going to receive it. So Slow is 2 months and fast is 1 month and immediate is 1 week. I am hoping to see my parts around the 1st week of July. Of course you will be 2nd to know and I will FedEx to you!
Outlaw1
posted June 21, 2004 02:40 PM
Have you done any adjustments to the TPS ?
Lead, Follow, Or get the hell outta the way.
posted June 22, 2004 05:43 PM
Embarassed to say after spending a lot of time and $250 for another set of throttle Bodies, I think I have resolved the problem. I also see the changes Kawasaki made to the 2001 throttle bodies, they used a smaller shaft to hold the plates for better air flow over the plates (10 MM Nut on the 2001 and 12 mm nut on the 2000 Belcrank!
OH Yesn the "Problem" the RUBBER cap that seals the vacuum tubes had a crack in it that leaked Just noticed when I removed it! I can not change throttle bodies in 1 hour or less! (Not anything I wanted to be that good at! Tomorrow the progressive Controller and retard! The retard is easy and the controller ??
ninja12
posted June 22, 2004 09:49 PM
I'm very interested in the wiring of these as i will be doing the same thing soon.
0.22744393348694 seconds processing time
