BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Scotts Steering Damper installation.... NEW TOPIC NEW POLL POST REPLY
deathpulse
posted June 16, 2004 10:27 AM
Ok guys, I'm going to go with a 17 tooth front sproket with my 190/50 rear tire profile.... so I'm considering a steering damper. The two contenders are Muzzy's and Scotts (I can use either on my 2000 model '12). The Scotts is a bigger name in steering damper tech, and is a bit cheaper (405 bucks as apposed to almost 600 bucks) BUT it says on the scotts site that it requires... DRILLING INTO MY FRAME (shudder). How hard is this to do? I can operate a drill ok, but is there a brainless template to use to set in up correctly, or should I just go with the non-drill muzzy model?
Hells Dark Lord
living life, and loving it.
posted June 16, 2004 10:31 AM        Edited By: Hells Dark Lord on 16 Jun 2004 11:47
i have used many steering dampers, and the Scotts is by far the best in my opinion.....there are quite a few guys out there that are using them on their bikes...I know Roger uses on on his 2000 12. And Lucky uses one also...as far as instalation goes, I have never done one on a 12, I put one on my 6RR..and it was straight forward. But I didnt have to drill the 6RR.....
If Roger cant fabricate me a mount for my 02 12...then I will prolly go with either the Hyperpro, or the Muzzy.....
your car is slow
Fuck Nitrous...Got Boost?
posted June 16, 2004 10:45 AM
yes you have to drill into the frame (neck) to mount the scotts.
Do not taunt happy fun ball!
deathpulse
posted June 16, 2004 10:49 AM
How easy is it YCIS? I guess the real question is - is it easy to determine the exact drill location (and get to the location to drill it)?
RAC4IT
Bergie
posted June 16, 2004 10:57 AM
it's easy, use a damp clotch in the airbox to catch the shavings
if you're scared, drop the extra coin and get the Muzzys, it's a bolt on and a nicer piece! no drilling!
your car is slow
posted June 16, 2004 11:27 AM
yea..its not a terribly difficult install...unless you have large hands and or forearms. Then its a bitch to get your hand in there to place the rag and or get the shavings out. a long flexible tube attached to a shopvac is quite handy though!
harryzx-12
posted June 16, 2004 04:26 PM
If you use 5/16-18 SS capscrews you don't have to put nuts on the back side.That's what I did. Drilled and safety wired them and loctited them upon installation. You have to enlarge the holes in the scotts frame that mounts to the frame and drill and tap the frame.I blew the shavings out the front with compressed air.
matt sterbator
Hiding in the bushes
posted June 16, 2004 04:44 PM
I've installed two Scotts on 12s. It's a chore, but it's not THAT hard. Measure twice, punch a mark, line it up again, re-punch if necessary, drill.
I put the lock nut in a pair of vice grips and held it in the air box... or just get your lady friend to hold the nuts
posted June 16, 2004 06:08 PM
Hey, got any lady friends to hold my nuts???
matt sterbator
posted June 16, 2004 09:48 PM
Harry has some really soft hands
harryzx-12
posted June 17, 2004 02:20 AM
Yeah, I'll wear my spiked gloves asshole!
0.2505030632019 seconds processing time
