BIKELAND > FORUMS > ZX12R ZONE.com > Thread: JE Piston Users that also use NOS or Turbo? NEW TOPIC NEW POLL POST REPLY
posted June 12, 2004 07:11 PM
When I measured the "Stock" Pistons in the ZX12, (Remember the stock bike has Forged Pistons also) the clearance was about .001". When I measured the Forged JE Pistons, they were between .0015 and .002 until I matched them to the best fitting cylinders and sanded them to get a tight .0025 at the Skirt and from what I measured this was just a little over .003 at 0.50 up the skirt.
I am now breaking in the rings for about 500 miles (About 250 with ND 30 Oil and 250 with regular Honda Oil) before I put the Motul e-Tech 100 back in the engine. The bike is making good power and seems to run well but the Pistons are "Loud"! I can hear them a lot more than the stock pistons.
My questions are:
#1, Are these clearances (Listed for the Piston set up by JE @ .0025 to .0035 for NOS) for engines with Aluminum Cylinder Walls (As opposed to steel lined Aluminun Cylinders)?
#2, Can any of you using the JE Pistons "Hear" the pistons? ( I also think they will be a little quieter with the 40 weight Oil, but not that much quieter!
BTW, I usually set up an engine a lot closer (About .0015) to get the heat transfer from the pistons to the cylinder walls and to lessen the piston rocking. But since this is for a heavy dose of NOS, I followed the reccomendations a lot closer!
canadamaxxer
posted June 12, 2004 09:51 PM
Vincent,
My JE 1270 pistons have some piston knock when cold. The knocking goes away by the time that it is up to temperature. Is yours knocking at all temperatures, or is it just cold as well?
floyd
posted June 13, 2004 12:23 AM
I thought the stock pistons in the 12s were cast.
posted June 13, 2004 02:57 AM
Thanks Maxxer, because yours should be tighter than mine! Remember I also have 30 weight Oil and it is in the 70 and 60's both times I have run it and it has really never heated up that much.
Read the Silver Book, at least the 2000 model had them!
cowboy
posted June 13, 2004 10:09 AM
Vincent,I believe the silver book is mistaken because the stock pistons that i have pulled out were cast.
0.23903298377991 seconds processing time
