BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 17t sprocket problem ??? Need help NEW TOPIC NEW POLL POST REPLY
SmurfKilla
posted October 18, 2001 12:09 PM
Has anyone here installed the 17t sprocket up
front and kept the back stock?
I just installed it and the chain is now hitting the
plastic piece on the swingarm close to the sprocket.
Does this upgrade require shortening the chain???
Thanks for your help
Cheers
SK
Tearinitup
VP Code Monkey
posted October 18, 2001 12:25 PM
Not mine
I put a 17 on the front of mine and didn't notice any clearance issues. I will check tonight.
posted October 18, 2001 01:35 PM
17T
I run a 17/46 on my bike and no problema.
Doug
griptwister
posted October 18, 2001 01:46 PM
Smurfkilla,I guess your talking about the plastic chain runner that protects the upper portion of the swing arm? If so, it will rub with the chain a little more than with the bigger sprocket. It will be still be ok when you sit on it and the shock compresses, changing the vertical angle the chain runs on.
My bike looks like it has about an inch of adjustment before hitting the end of the swing-arm. So don't shorten the chain. Dan.
FuckMeRunnin
posted October 18, 2001 04:06 PM
I've been running a 17t frint for a long time with no problems.
"What happens if you get scared 1/2 to death twice?"
SmurfKilla
posted October 18, 2001 05:30 PM
17t sprocket
Well just came back from first ride with the 17t and man
it has really changed this bike.
Roll on power in 1st and 2nd is even more awesome. Wish I had done this beginning of summer. Oh well.
The chain still rubs on the plastic swing arm protector even when sitting on it and I can hear it when coming to a full stop.
Looking at it, it appears the angle of the chain is just catching the end of the swing arm on that plastic protector.
One thing I noticed when putting everything back on, I really had to adjust my chain adjust bolt way out, but this would make sense as changing only the 17t should make it longer correct?
Anyway any suggestions would be appreciated.
Cheers
SK
Ninjaman12R
as a Deal's Gap tour guide.
posted October 18, 2001 05:52 PM
I don't think you've got anything to worry about. Several people here have been running a 17t for quite sometime with no problems. I have only had mine on for about 6 weeks and I also went up one in the back. I can't say enough good things about this combo. It rocks!!!
0.21669912338257 seconds processing time
