BIKELAND > FORUMS > ZX12R ZONE.com > Thread: PCIIIr connection problems NEW TOPIC NEW POLL POST REPLY
Farmer Rog
posted June 02, 2004 08:13 AM
Yesterday I had problems connecting the computer to the Power Commander. It would connect sometimes and not others, both with and without the motor running. Tried several cables, took out the #9 pin on the cable as per the Dynojet tech advice, but still no better.
Also, one time changing the face-plate bars worked backward from the indications on the faceplate. Three bars richer and it got leaner on the dyno.
Bad connection, ground, etc., or is it just on it's way out???
ZX-12R, stock motor, Muzzy/PC3 63in, 60-shot dry, 750#, 9.001
ZX-14, stock motor, Brock smeg/PC3, 63.5in, ~750#, 9.31 NA, 8.95 40-shot dry.
NorthwestDragbike.com
Farmer Rog
posted June 04, 2004 07:06 AM
Guess everyone is happy with their PCIIIr's??
I'm the only one with problems?
beansbaxter
posted June 04, 2004 09:02 AM
I was just refraining from a hijacking is all...since I dont know an answer for ya...
posted June 04, 2004 07:29 PM
sounds like it has a prob.. .I'd contact DJ's tech support and ask them..
Hells Dark Lord
living life, and loving it.
posted June 05, 2004 03:53 AM
I had issues with software compatibility. I bought my PC and installed the software to adjust it...it worked fine....MY buddy bought a newer PC and had newer software for his GSXR, I installed the newer sofware to adjust his pc. Now my PC doent see the software in the computer.....and I dont have the disk that had my older software version.
Rog, there have been plenty of issues with PC formthe membership on this board. Ihave heard of guys having 2 and sometimes 3 PC's
go bad. If I am not mistaken, most of the PC that go bad are PCIIIr's......sounds like I might have to do a poll.......
canadamaxxer
posted June 05, 2004 06:59 AM
HDL:
I have the "software version incompatible with Power Commander" prompt come up everytime I try to load the map out of my bike. There is a solution to that: load a map from your hard drive (Or a floppy) to the PC3 program and then go to the toolbar at the top and click on "utilities" and then down to "get all". The map you loaded from the hard drive is now gone and the map from the bike is loaded to the PC3 software. Unless DJ has something new going on in the last few days, I have the latest software. I have tried the disk that came with my PC3R and it will work fine. You should be able to work around this situation. It seems sloppy to me, but maybe Tearinitup has input on the subject.
canadamaxxer
posted June 05, 2004 07:02 AM
As far as the original post goes: I would think the unit is faulty. Eliminate the obvious: check for good ground (test it with a DVOM....maximum resistance: .10 ohm), good power (check voltage drop across the connector) and confirm the connection to the bike harness. If all is well, then I would think the PC is hooped.
Hells Dark Lord
posted June 05, 2004 08:30 AM
thanks Maxxer I will give that a try....
Farmer Rog
posted June 11, 2004 08:24 AM
UPDATE:
Dyojet found my PCIIIr faulty, and even though it was out of warranty, they're giving me a new one for free!!
Good Job Dynojet!
posted June 11, 2004 09:24 AM        Edited By: CrotchRocket on 11 Jun 2004 10:27
I dont have a PC3r, ever since it went bad on my 2000 12...My 2002 just has the pipe, fuck the PC...When the PC goes bad it dumps too much fuel into the motor...
posted June 11, 2004 09:26 AM
that makes sense.. that's like saying (if the bike was carb'd) I had problems with the new needles and jets I put in... fuck them.. I'm running the carbs stock
Hells Dark Lord
posted June 11, 2004 10:06 AM
lol....I wouldnt run my bike without the PC, it made a world of difference in the riding and running of my bike, made it a pleasure to ride.....so smooth, compared to some bike I have ridden....but not as smooth as stock.....but close...
craigb29
posted June 12, 2004 07:56 AM
does anyone have an release date for the pc for the 04 zx12?
Hells Dark Lord
posted June 12, 2004 11:44 AM
fish could prolly answer that question.....or knows someone that can....
posted June 12, 2004 12:50 PM
I could try to find out, but a certain member here has kinda "killed the goose that laid the golden egg" with regards to DJ on this site.
Hells Dark Lord
posted June 12, 2004 03:51 PM
that sucks....its always nice to have the hook up on these things.....
posted June 12, 2004 05:34 PM
was nice to "have had" the hook up on these things
Hells Dark Lord
posted June 13, 2004 03:52 AM
dats what I ment....
Tearinitup
VP Code Monkey
posted June 17, 2004 09:45 AM
http://www.powercommander.com/216-411.shtml
Moments...
0.35110306739807 seconds processing time
