BIKELAND > FORUMS > ZX12R ZONE.com > Thread: MadMike ROCKS!!!!: 48mm throttle bodies!! NEW TOPIC NEW POLL POST REPLY
posted May 22, 2004 03:51 PM
I came back from a biztrip expecting to find a small pkg from MM with a spacer to use with the degree wheel.
well..... just as expected, there was a pkg from Mike, but is was bigger than needed for one tiny spacer. Seems he had some extra space in the box and threw in a set of 48mm Bear modded TB's to help fill up the box! You DA MAN!!!! Mike. Whatta surprise
Now I have to find a set of 48mm stacks; time to get in touch with Pierre.
Vincent, do you know Pierre's contact info??
tbird_94
posted May 22, 2004 06:44 PM
What year is the bike? I have an '04 and there seem to be a lot of restrictions om it.
posted May 23, 2004 01:44 AM
tbird,
i have a y2k, and as far as i can tell there are no restrictions anywhere, i.e. no parts which when repaced with aftermarket stuff gives instant BIG gains. OEM head, cams, CR, timing, are all very close to optimum.
I understand that later 12's do have a mph limit of 186, but basic motor is not restricted as far as I know.
0.22272896766663 seconds processing time
