BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Oil Squirters? NEW TOPIC NEW POLL POST REPLY
posted May 19, 2004 02:33 PM
Oil Squirters?
I just noticed that I only have "2" Oil Squirters? There is a Boss that could be used for the other 2 pistons. Is this normal? My Porsche had one for each piston as opposed to #2 and #4 pistons like in my Bike.
slug
Out in search of my mind...
posted May 19, 2004 07:14 PM
are 2 & 4 centre? (not sure on the zx12 how the numbering goes)
those will run hotter, perhaps they figured outerones didn't need extra cooling?
my 600 has a dual jet between 1&2 and 3&4, so each piston gets a healthy shot of oil
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
posted May 19, 2004 09:17 PM
Vincent
Yes, you have two. We all have two. My take is that Kawasaki found that those two cylinders needed the extra cooling oil due to a lack of splash and that they found that the other two got sufficient oil and so decided to reduce the oil in windage and conserve the flow. You can drill the bosses and put the jets into the blank two if you want and I might do that on a "big" or "severe duty" Maxton? Bonneville? engine.
Doug
johnnycheese
posted May 19, 2004 09:32 PM
just did Entropy's tonight
posted May 19, 2004 10:25 PM        Edited By: entropy on 19 May 2004 23:28
just did Entropy's tonight (12:32am)
dang JC, do you ever sleep?????
I just got some real purty jewelry from Muzzy; see you on Fri!!!
posted May 20, 2004 03:46 AM
Thanks Doug, I will look under the Pistons tops after the next Maxton to see if there is any carbon as opposed to the deep brown shine.
posted May 20, 2004 10:23 AM
Vincent, If you see "carbon" under there it will be during the autopsy. These engines rarely get more than a light brown shine, especially with the synthetic oils.
Doug
posted May 20, 2004 11:03 AM
Doug
Good One Dr. Doug
I needed that smile today! (I am still laughing! your timing was perfect, what a day!)
tn1361
posted May 20, 2004 02:27 PM
Anybody know if you can purchase anything to increase the volumetric flow of the oil pump ? Seems like this may help solve the oiling problems that many of us are having.
psycho1122
posted May 20, 2004 10:01 PM
12's don't have "Oiling Problems"
Inspect your pump Rotor/Stator and your pick-up. If Rotor/Stator have any nicks etc.-REPLACE.
Make sure pick up is clean and don't underfill your system.
psycho1122
posted May 20, 2004 10:04 PM
Question Gentlemen;
Could the "Squirters" be a means of "Metering" oil flow at the rod feeder main bearings?? These do come off the #2 & #4 mains.
posted May 21, 2004 06:33 PM
Psycho- yer thinkin' too much again.
tn1361- What oiling problems?
Vincent- glad I could help bring you a grin.
Doug
psycho1122
posted May 22, 2004 08:54 AM
You say "Psycho" like it's a bad thing!
Ok! Ok!
0.23474383354187 seconds processing time
