BIKELAND > FORUMS > ZX12R ZONE.com > Thread: full 4-2-1Hindle stepped race system NEW TOPIC NEW POLL POST REPLY
Megabyte
posted May 19, 2004 11:41 AM
My 1361 is making 212 RWHP w/a full Acro system. Would a full 4-2-1 Hindle stepped race system make more?
Michael Lee
Purchase Ivy
posted May 19, 2004 12:52 PM
Seems like your making more than enough now? Sweet numbers . . . besides the pistons could ya list other engine add ons . . . pleeeeezzzz !
posted May 19, 2004 02:30 PM
Agreed!
Megabyte
posted May 19, 2004 04:05 PM
2K KAWASAKI ZX12R
BMC Race AIR FILTER
AKRO FULL EXHAUST SYSTEM
MVR Built 1361
PCIIIr
MUZZY HIGH VOLUME FUEL PUMP
WISECO PISTONS
Muzzy Adjustable Cam Sprocket
Muzzy Fan
Muzzy Gold Velocity Stacks
Manual Cam tensioner
Counter Balancer removed
Muzzy Block Off Plates
Muzzy Clutch
Heat Blanket
Oil channel Mod for Increased oil return from head
Vacuum on crank case Mod
Balanced & Super teched all parts
MVR Ported heads
Michael Lee
Purchase Ivy
posted May 19, 2004 05:25 PM
Just one more thing how much was the porting. approx.
Megabyte
posted May 19, 2004 09:00 PM
I believe it was around $800.
posted May 19, 2004 11:28 PM
megabyte,
i do think you'd get a lil more hp here & there but no dramatic increases. You seem to have a really strong motor, i wouldn't screw with a good thing if I were you.
Michael Lee
Purchase Ivy
posted May 20, 2004 08:06 AM
Suspension upgrades?
rac4it
Bergie
posted May 20, 2004 09:43 AM
No the Hindle won't make more power. Look into the Muzzys Pro pipe with that setup.
posted May 20, 2004 11:55 AM
Bergie, Isn't the "Pro-Pipe's main advantage in the power it makes at "Higher" than normal RPM? (Which you need to change the rev limiter to also use). I do not think he is spinning the engine 12 and 13,000 rpms nor do I think he wants to?
I would think Brock Davidson's alterations in the Hindle would work better that the standard Step tube. Also I think the Regular Muzzy Pipe would be better than the Pro-Pipe?
Megabyte
posted May 20, 2004 01:50 PM
Hi Vincent, Muzzy has twice advised me not to use their pro pipe unless I raise my RPM limiter. Also, I've read, heard, and seen, so much positive data on the Hindle, that I'm really wondering if I could make enough more HP with it to justify the expense ? BTW, Where would I order Brock Davidson's Hindle ?
Thanks,
posted May 20, 2004 02:14 PM
Thanks, Brock's pipe is expensiveI would get a Step Hindle from DOug at Spencer Cycle and remove the Divider plate in the collector (After you test it with it in place. That way if it was better, just get another collector)! Then you will have 99% of Brocks Pipe. The only difference then would be the .25" larger outlet on the muffler! If I had to hazzard a guess, The Best possible increase would be up to 220 Hp. My bet is that it would mostlikely be 215 to 216 HP
Reember I gained 10 HP over the Akra but with you bike so close to the limit, 3 to 5 HP would be "BIG"!
posted May 20, 2004 03:17 PM
220hp outa a 1361???? only on the happiest of happy dynos, cams, nutec and HIGH compression...
posted May 20, 2004 03:48 PM
If you notice My true feelings is more like 3 to 4 more HP
BA
posted May 20, 2004 07:46 PM
...I would get a Step Hindle from DOug at Spencer Cycle and remove the Divider plate...
by george, I think he's got it!!! .....ya know, it warms my heart to finally see someone else make the point about that darn divider!
posted May 21, 2004 01:59 AM
What about a TiForce?
RAC4IT
Bergie
posted May 21, 2004 02:58 PM
I believe Tim's bike had a Muzzys Pro pipe and cams when it went consecutive 208+ MPH runs naturally aspirated at Maxton. No other pipe has done that yet on a 12R without nitrous or boost.
0.24528789520264 seconds processing time
