BIKELAND > FORUMS > ZX12R ZONE.com > Thread: burnt smell NEW TOPIC NEW POLL POST REPLY
aliveagain
posted May 17, 2004 07:25 AM
burnt smell
coming from my tail piece.Unhooked the PCIII and it isn't as strong but definately has that bad ballast type odor.Is this normal or am I on the way out?
osti33
posted May 17, 2004 10:09 AM
Sounds like oil in the stator connector to me. Many people have had this problem. Kawi issued a recall on it.
Pull the rear seat off and pull the connector apart and see if it has oil in it. If so you have found your problem.
Ryan
Ra12r
posted May 17, 2004 01:36 PM
Yep!!!
REDX
posted May 17, 2004 02:26 PM
got the same problem. heard that even with the recall it keeps happening.
aliveagain
posted May 17, 2004 06:24 PM
you guys called it.All oily and smells like shit.I couldn't get it undone even with the seat off,its late so I'll look at it tomorrow.If the dealer fixed it once,are they responsible for it now?Does it cause any harm to the voltage output?
your car is slow
Fuck Nitrous...Got Boost?
posted May 17, 2004 10:15 PM        Edited By: your car is slow on 17 May 2004 23:16
I dont think it actually hurts anything...other than the obvious fire hazard
highly flammable petroleum products go well with electricity....like peas in a pod!
Do not taunt happy fun ball!
wannabe
posted May 17, 2004 10:38 PM
I disagree YCIS. The oil shorted the leads in the connector under my seat. That made it so the battery didn't charge. The dealer ended up having to replace the voltage regulator.
And, yes, aliveagain, if the dealer fixed it once, and the problem came back, you should be able to count on them fixing it again.
your car is slow
posted May 17, 2004 11:20 PM
sarcasm doesnt travel well on the internet
REDX
posted May 18, 2004 04:47 PM
true true guess you need happy faces for people to tell its a joke.
aliveagain
posted May 20, 2004 05:17 PM
Dealer looked at bike and wouldn't fix it again.They said they were trying to get ahold of Kawasaki to see if there is another fix and who would pay for it.
lou_zx12r
One Day at a Time
posted May 21, 2004 09:50 AM
A recall is a recall is a recall! If it's not fixed the danger/hazzard still exist. I had the gas tank & gauge recall done 2 years ago and this spring it went back in for the recall again(i also don't have the extended warrantee). Kawasaki told the dealer they didn't want to fix it, my dealer asked several times before they told me that it was an up-hill battle. I call kawasaki and explained that it is as much of a danger now as it was before the fix since the problem has not been corrected, and that I would hold them responsible. It worked, they went ahead and notified the dealer to fix it again. Sometimes you need to apply a little pressure to make someone do what is right.
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
0.26386380195618 seconds processing time
