BIKELAND > FORUMS > ZX12R ZONE.com > Thread: bike keeps cutting off NEW TOPIC NEW POLL POST REPLY
n_pride
posted May 17, 2004 04:44 AM
I have a 12 with the 1270 kit, full yosh, pcIIIr and K&N's. Problem is the bike keeps cutting off if the idle is less than about 1300-1400 rpm's. It does this if the motor is hot or cold. Kind of embarrassing to have to start your bike at every red light. Any ideas?
your car is slow
Fuck Nitrous...Got Boost?
posted May 17, 2004 06:11 AM
raise the idle a bit?
Do not taunt happy fun ball!
frEEk
posted May 17, 2004 09:00 AM
i aint no expert but the first thing that come sto mind is the map in your pcr. maybe disconnect the pcr temporarily and see if it still dies.
ninja12
posted May 17, 2004 10:00 AM
Add fuel to the lower end with the pc3. if that doesn't help
remove fuel. IF nothing helps then remove pc3.
IT's probably in the map.
BA
posted May 17, 2004 01:20 PM
I agree with all that. Idle speed, remove PC3, check PC3 ground.
Ra12r
posted May 17, 2004 01:34 PM        Edited By: Ra12r on 17 May 2004 14:35
There is a map fix that will help. It offsets fuel values at the O% throttle position up to 1500-2000rpm. Makes it idle smoother too. I can email you my map, and you can copy and paste that area of the map to try. PM me with your email.
0.24165511131287 seconds processing time
