matt sterbator
Hiding in the bushes
posted April 26, 2004 05:58 PM
Valve cover gasket leaking...
For the past few thousand miles I've had a slight oil leak from the left front corner of my valve cover. It wasn't anything real bad but it would get on my fairing and sometimes my boot.
Last week I finally check my valve clearances (10,700 miles, all in spec) and reinstalled the valve cover. The gasket stayed on the head, I cleaned up the lip on the valve cover and the top of the gasket and used some Permatex ultra black RTV silicone sealant to help fix the oil leak. I rebuild Mustang T5 transmissions on the side and have used this stuff extensively. I figured if it would work with ATF, it'll work with motor oil. I only used it between the valve cover and the gasket, not the gasket and the head.
Long story short, it still leaks, only worse, lol. It appears to be coming from between the gasket and valve cover.
I had ordered a new gasket from Ron Ayers but thanks to their SLOW ass shipping dept, it hadn't, and still hasn't arrived yet.
Any help would be appreciated
pdb1964
posted April 26, 2004 06:49 PM
I have the same problem, although it is very minor. It originally started when I brought the bike in for service and on the way home, the left side of the bike was soaked. I checked the valve cover bolts and some were lose. I was very disappointed with the workmanship. Anyway, I tightened the bolts but it still leaks. It is very minor. Just enough for the left front of the engine to get damp. I'm just guessing but maybe it has something to do with the sequence in which the valve cover bolts get tightened. If done wrong, can the valve cover get twisted enough to cause a leak? I'm thinking that a valve cover gasket wouldn't TX (time expire) after only 2 yeras on the bike (mines an 02)
your car is slow
Fuck Nitrous...Got Boost?
posted April 26, 2004 06:55 PM
Sweat from all that horsepower.
Do not taunt happy fun ball!
matt sterbator
posted April 26, 2004 07:07 PM
I looked for the valve cover bolt tightening sequence in the service manual but didn't find it. So I started from the inner bolts and worked my way out.
B... so can I use anti-perspirant ?
your car is slow
posted April 26, 2004 07:15 PM
Yea...but for your bike since its that sissy green color....make sure you get SECRET
You know..strong enough for a man...but ph balanced for a woman
goddamn that was too easy!
pdb1964
posted April 26, 2004 08:24 PM
LOL. Good one!
matt sterbator
posted April 26, 2004 08:49 PM
Oh now you've got jokes !!!
matt sterbator
posted April 27, 2004 04:02 AM
I'm just gonna RTV both sides of the gasket if no one knows a better solution, lol.
canadamaxxer
posted April 27, 2004 04:54 AM
A new gasket should work fine. Typically if there is no torque pattern specified, tighten in a sprial from the centre of the piece out. The biggest thing is to make sure that the torque is even on all the bolts. I torqued everything when I put my engine together...with a torque wrench ...and I pull wrenches professionally. As far as the RTV goes...I wouldn't do it. I just installed my valve cover after a rebuild and just used some Permatex Anaerobic gasket maker (red clear sticky thick liquid) on the half moons for the cam cutouts, and that's it. My policy is to Never reause gaskets or o rings. It's just not worth it. Pollution and atmospheric conditions cause rubber seals and gaskets to harden and deform with time.
These are Japanese engines...they're not supposed to leak. If it leaks, that ain't right.
canadamaxxer
posted April 27, 2004 05:00 AM
The biggest thing is to ensure that the surfaces are CLEAN!! Scrape off any residue from the old gasket, then use brakeclean on a clean cloth and wipe the surfaces. Then spray the surfaces with brake cleans and blow them off with compressed air (I have a compressor, but a can of compressed air from an electronics store is just fine as well). Here is the last trick: make sure that any hands that are touching the gasket are as free of oil as possible...better yet wear latex or nitrile gloves to keep the oils from your skin off of the gasket.
your car is slow
posted April 27, 2004 05:54 AM
Mines always leaked. Not enough to worry however. I reused the gasket and RTV with little effect.
matt sterbator
posted May 04, 2004 02:08 PM
Edited By: matt sterbator on 2 Aug 2004 10:14
Ok, I just cleared everything out of the way.
right side of the bike, second valve cover bolt in, on the back side. It appears to leaking from the valve cover bolt hole, around the bolt. It's leaking, and dripping down the valve cover to the left side of the bike. Can't tell if it's been leaking at the valve cover gasket since it's covered with oil.
matt sterbator
posted August 02, 2004 09:14 AM
Thread resurrection (not erection, calm down you fags), lol.
New valve cover gasket finally showed up last week. Speedy shipping Ron Ayers, lol. Only took 3 months...
Anyway. That bike is still leaking. Same spot it was leaking from before. I tried some black permatex silicone sealant, and that did nothing. Now, I did the Kleen Air removal at the same time I checked the valves, and it started leaking from the bolt at this time (blocked off the stock plates).
Could I have don't something wrong here and now somehow it's forcing oil past the little seal on that bolt ? It's still leaking from that corner as well, but the majority of the oil is leaking from the bolt hole and running down the valve cover.
Any suggestions before I go and just slap this gasket in place ?
posted August 02, 2004 10:04 AM
Edited By: dougmeyer on 2 Aug 2004 11:05
If you have a leak, something's not right (Duh....) and you should keep looking until you find it. The way to minimize the chance of a leak is to (as stated above) dry the gasket with a good contact cleaner, dry and clean the head and cover in the same manner. Use NO RTV or anything else. Install it DRY. Check the locating dowels at the plug wells to make sure they are down all the way. Replace the bolt seal washers (and make sure they are installed correctly with the washer side up) Clean and dry these as well.
Doug
your car is slow
posted August 02, 2004 10:14 AM
Edited By: your car is slow on 2 Aug 2004 12:45
I still think its just sweating from all that horsepower
matt sterbator
posted August 02, 2004 11:05 AM
Thanks Doug.
posted August 02, 2004 12:48 PM
Actually,I mis-spoke. Replacing the seal washers isn't mandatory- juts inspect them, and you might swap them around unless you find a bad one.
Doug
Marcos Peguero
posted August 02, 2004 12:56 PM
My last zx9 had that problem and I intalled the gasket the way Canada and Mr. Doug sugested with contact cleaner and problem solved.
matt sterbator
posted August 02, 2004 03:48 PM
quote: Actually,I mis-spoke. Replacing the seal washers isn't mandatory- juts inspect them, and you might swap them around unless you find a bad one.
Doug
Funny, I was about to post something about buying some new seal washers and then thought about possibly switching them around, lol.
I'll def give them a close look. Thanks again.
tuusinii
posted August 02, 2004 10:10 PM
I also had this same problem and now it seems that the problem wasn't the valve cover but the cam position sensor o-ring leaking. I put some RTV on it and now it won't leak enymore. Allthough I allready have the new valvecovergasket + 4 little ones for the plugs. And I don't see why should You change the cover casget with every opening - waste of money.
posted August 03, 2004 04:23 AM
I still have my original gasket and I have removed it oh about 200 times... I use a very thin layer of RTV on the head only and then place the gasket on top, hardly ever have any problems and if I do I just repeat the process. if I was just street riding and only removed it once in a blue moon I would just use a new one. I always try and use a new Oilpan gasket everytime though.
dave
posted August 05, 2004 05:30 PM
mine was leaking from the front corner on each side , i put a flat washer(10mm) under the head of these two leaking bolts and the problem was solved.
posted August 06, 2004 05:39 AM
I also had the leaking valve cover on my 2000, but it didnt leak until I started using synthetic oil...
Any of you guys have the same experience?
