Mr Beetleman
posted April 26, 2004 11:15 AM
Electrical troubles....Please help!
My battery keeps dying...
I had it tested and it is ok. (New battery, only a few months old).
If I boost (battery charger on pigtails) the bike fires right up with lots of power to the starter. After riding for some time, it will be charged enough to restart very easily.
If I don't ride for a few days, I get a very weak starting attempt that will rarely start the bike. I usually have to reconnect the battery charger, etc...
I have removed the ground wire from the battery, and connected an ampmeter between the ground & the battery. It reads the little blip of power it uses to move the speedo & tach needles, but after that it reads zero.
I am left with two choices:
1: A short somewhere that I am not finding with the ampmeter.
2: The stator isn't recharging the battery enough to hold a charge...
How can I find the source of the troubles?
Please help, thanks.
My bike has a larger engine than my car (1973 Austin Mini 1000)!
dontwanna10
posted April 26, 2004 11:27 AM
It sounds like the battery may actually be bad ...Have you had it LOAD tested, I know you said you had it tested but it sure sounds like your battery is just holding a surface charge.
12r's forever
wilson1
posted April 26, 2004 11:44 AM
Edited By: wilson1 on 26 Apr 2004 12:46
check out put of the stator they have been known to go bad us a volt ohm meter
Mr Beetleman
posted April 26, 2004 04:09 PM
I took it to another garage, and had it LOAD tested. They instantly found out that it WAS bad. The dealer said that they'll replace it.... So I think the problem is solved....
wilson1
posted April 26, 2004 04:11 PM
good
dontwanna10
posted April 26, 2004 05:37 PM
Cool Man, I don't know why some people out there think they can test the voltage of a batter to tell if it is good. There are many times that a battery will show 12.6V but drop to 4 or something under load with a bad cell.
12r's forever
pdb1964
posted April 26, 2004 06:52 PM
Edited By: pdb1964 on 26 Apr 2004 19:52
Same thing happend with my truck batteries (I have two, diesel). Test fine with no load but won't hold a charge, or doesn't have the amps to turn over the engine. From now on, I'll have the battery load tested if I have a battery problem.
wannabe
posted April 27, 2004 06:32 AM
Err..umm...how about a completely different solution? The same exact thing was happening to me. It turned out that a bunch of oil had wicked up the stator cable and flooded the connector under my seat. The oil was shorting out the connector which didn't allow the stator to charge the battery. I finally brought it in to the dealer to have the recall done. They cleaned out the oil and replaced the voltage regulator (just in case.) Problem solved. No charge.
