BIKELAND > FORUMS > ZX12R ZONE.com > Thread: reusing piston pin clips?? NEW TOPIC NEW POLL POST REPLY
cowboy
posted April 25, 2004 01:41 PM
Shop forgot to order new piston pin clips for the muzzy 1270 kit?These ones only have about 1000 miles on them and the motor came apart because of a dropped exhaust valve.We're putting two new pistons and a full set of rings but is it really necessary to instal new cir clips?Just means the bike will be down for a week longer again!
slug
Out in search of my mind...
posted April 25, 2004 02:13 PM
i replace mine even on the 600, with stock internals
it's just not worth it to save a bit of time to take chance on the used clips being weakened and letting go at some inopportune moment...
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
Ra12r
posted April 25, 2004 02:30 PM
I have reused mine many times. As long as they still have the spring pressure.
canadamaxxer
posted April 25, 2004 02:46 PM        Edited By: canadamaxxer on 25 Apr 2004 17:35
My perspective is this: Do I want a $1.50 clip to cost me a $3000 to $4000 engine? I would never re-use any of those clips. To me it's like reusing cotter pins.
ZXLNT
posted April 25, 2004 03:47 PM
What he said. Do it once, do it right...
posted April 25, 2004 09:25 PM
AMEN Brother!!!! Dude do not re-use the clips.
Mad Mike
cowboy
posted April 25, 2004 09:29 PM
Shit,I thought you guys were going to say that
posted April 25, 2004 10:26 PM
I love reusing cotter pins! Matter of fact.. I use them for everything I can!
Send me your used cotter pins!
ra12r
posted April 26, 2004 06:23 AM
Remember all........new does not mean "fail safe". The issue is spring pressure, clips snap into place and are not (or shouldn't be) under much mechanical lateral pressure from the wrist pins. I understand your point, but last I checked ALL of us posting have had failed motors with what was "NEW" parts.....hmmmmmm
Just a thought, does it matter how much the part originally cost if it fails and ruins your motor?! $1.50 or $1500.......The cost is just the same to fix it. Oh, one more question...How many have had wrist pin clip failure??
posted April 26, 2004 07:45 AM
I would only re-use if I had NO other choice. But having said that, if your clip is undamaged and has the same relaxed shape and flatness as new a one, the chances of a failure are pretty remote. This statement only applies to round wire circlips, not spiroloks, which are never to be reused. The most important factor is the groove. On a used piston, the groove can be damaged from careless removal of the wire. And if the pin length is wrong, or if the pin end is not chamfered correctly, the pin can bang against the wire causing the groove to deform.
Doug
cowboy
posted April 26, 2004 08:02 AM
Thanks everyone
cowboy
posted April 26, 2004 08:07 AM
Also ,does the Muzzy 1270 kit use oem circlips?
posted April 26, 2004 08:28 AM
No, they have their own circlips. that come with the kit.
0.22640204429626 seconds processing time
