BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Scraping swingarm NEW TOPIC NEW POLL POST REPLY
zzzzzxxxxxr12
posted April 17, 2004 06:25 PM
Scraping swingarm
Is there a special set of swing arm spools that keep the rear bike stand from scraping the swingarm? I hold the bike straight up and it still rubs when you raise the rear up. I even tried bending the stand forks out. seems the spools are not offset enough. Anyone else have this issue?
beansbaxter
posted April 17, 2004 09:17 PM
nope....2002 12 if it matters...I know the swingarms are different between the 1st and 2nd gen 12's
REDX
posted April 18, 2004 05:48 AM
use a pitbull stand and you won't need spools
DaveInDaytona
posted April 18, 2004 07:15 AM
Or use a spooled Pitbull stand and you won't have a problem because they hold the adjustment and stay within the spools.
I bought the SS rear from Pitbull because you can flip the mount and also use it on bikes that don't have rear spools, you get the best of both worlds and no scratches.
The Muzzy spools are wider if that will help.
DaytonaSportbikes Forum
ZXLNT
posted April 18, 2004 03:39 PM
Same with the protekk.com spools, lots wider than most and keeps the stand off the swingarm....
zzzzzxxxxxr12
posted April 18, 2004 03:42 PM
Wow i think i will get some of those from protekk,
beansbaxter
posted April 21, 2004 08:42 AM
I have the PitBull ones on mine, but they are working with some custom service stands made by Dino himself...wuhahaha I love em!
Hells Dark Lord
living life, and loving it.
posted April 22, 2004 03:43 AM
zzzzzzzxxxxxxx...Protek also has some sweet swing arm spool/slides you aught to check out. The spools in ZXLNT, look like the slider spools...they are a neat concept....
busakillerzx12r
posted April 22, 2004 05:24 PM
My stands are from Handy Industries and i got some spools from the local suzuki store and mine never hit. My stand is adjustable though so it would never hit..
______________
BusakillerZX12R
zzzzzxxxxxr12
posted April 22, 2004 06:10 PM
I was looking at the pics above and i think i may have the wrong spools. I rear lip does not clear the swingarm. All the ones above have the inside lip protecting the swingarm, or is the mount on the 2000( like mine) that much different?
0.2564971446991 seconds processing time
