KawRider
posted January 07, 2002 10:54 PM
Off Topic- Timing Belt Lesson Learned
Well... I am usually a complete maintenence Nazi with my bikes AND cars.... I have known for quite some time that I need to change the timing belt on my 94 Toyota Celica. I have been talking about changing it for 30000 miles! There always seemed to be something more important, or more fun to do... so I kept putting it off and putting it off. Until.... bam... it skipped a tooth the other day. The car started lurching and generally running like crap for a few blocks. I managed to drop wifey off at work, and get to a gas station. Then it simply quit running at idle. I immediately knew what it was the timing belt. This is the original belt, and the car has 128000 miles! The book calls for 60K replacement, but I know better, and had decided to run it for about 100K or so (It's a Toyota after all). Then 100K came and went. It seems like I always had some other vehicle related expense... like new snow tires... or Exhaust for the 12R . So here I am... praying to the motor gods that I don't have valve to piston contact, and I will not have to do a top end re-build. Put on a new timing belt and guess what....................
she purrs like a kitten!!!
Sweet! Anyways... I just thought Id share with the group...
I mean Im a complete maintenance freak... I change oil every 3K RELIGOUSLY.... I (usually) never let anything go. Maybe that's why the maintenance gods went easy on me. I really learned my lesson. Could you imagine... a motor rebuild over a $35 part? Anyways... that's my lesson learned... and I hope you all can benefit from it. Im just glad it didn't happen at 100MPH on the Autobahn. Does anyone happen to know how to find out if you have a "no-interferance" engine? It would definately be useful info.
Tim
Black ZX-14
lubricity
posted January 08, 2002 02:58 AM
Lucky it didn't break and bend valves.
a poor 12 owner
Koz
posted January 08, 2002 04:25 AM
Timing Belt
I've had several Toyota's in the past 15 years. I've had the timing belt let go at about 75mph (with manual and auto trans) on two different Toyota cars. I replaced the belts on both with no problems. I was told that Toyota engines are designed not to have valves hit pistons when the belt breaks. The one thing you may want to do is replace all the other parts that can fail while you've got it apart, such as water pump, thermo, belts, hoses, etc. Also you MUST use Toyota parts!
Koz
