BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Muzzy kleen air block off plates NEW TOPIC NEW POLL POST REPLY
RICKV
posted April 10, 2004 06:44 AM
I am in the process of installing Muzzy block off plates
(removing the Kleen air system). It comes with gaskets and instructions. Its stating to leave the existing reed valves in place and install the Muzzy gasketes and block off plates, but it doesn't mention to remove, or leave the factory o-rings. It seems to me the factory o-rings would seal the block off plates, and you wouldn't need the gaskets. If any of you have done this procedure, I would appreciate you feedback and help.
Thanks Rick V
kcadby
posted April 10, 2004 12:14 PM
I leave the reeds in and don't use the gaskets...
danohall
posted April 10, 2004 07:38 PM
RE: Block Off Plates
I left the reeds in and also didn't use the Muzzy gaskets. The stock O-Rings sealed just fine.
JoshDunn
posted April 10, 2004 09:44 PM
I just plug the hose, anything wrong with that?
Hells Dark Lord
living life, and loving it.
posted April 13, 2004 12:07 PM
What avantages does this have...performing this mod on a bike? How do stacks effect your bike?
posted April 13, 2004 12:33 PM
The reed block-offs have no performance advantage. They were designed for race engine builders as a convenient and visually appealing way to cap off the KCAS assembly. It enables you to remove all the associated plumbing reducing weight and clutter. In some applications, backfiring on the over-run is reduced.
Doug
Hells Dark Lord
posted April 13, 2004 12:55 PM
thanks Doug...what about the velocity stacks?
WrenisPinkle
that's Mr. PINKLE to you
posted April 13, 2004 08:37 PM
Velocity stacks?
Doug,
Yeah, what about velocity stacks? Just how modified does ones engine need to be before the larger stacks can be used? And what advantages can be expected from using one of the smaller versions? I am completely in the dark when it comes to the use of the velocity stacks. Please enlighten me?
Ted
Hells Dark Lord
posted April 14, 2004 04:53 AM
I see on Muzzys site they have stacks for basically stock motors, and some for minor upgraded motors, and some for serious motors?
busakillerzx12r
posted April 14, 2004 05:04 AM
I dont think your motor needs to be modified to use them because they make them for a stock motor. All their doing is letting more air in...they should be O.K.
_________________
BusakillerZX12R
posted April 14, 2004 11:02 AM        Edited By: dougmeyer on 14 Apr 2004 13:19
We make no specific power increase claims for the billet stacks, we consider them a tuning aid. We make them in two lengths, longer (blue) and shorter (gold) than stock. The diameter is stock to match exactly with the stock throttle bodies. Also the machined radius on the inlet is correct for maximum airflow at the entrance. The shorter stacks bias the inlet tuning to increase flow in the upper rpm ranges and the longer stacks do the opposite moving the torque peak down somewhat. The stacks should "work" similarly on any engine from stock to very modified but only to the degree that power curve of that engine can take advantage of them.
Doug
Otis
Captain Kickstand
posted April 14, 2004 11:25 AM
I just plugs the tubes. I pulled out my old ZX-11 block off plates, but the holes didn't fit so I bought threaded copper plumbing plugs and screwed them into the hoses. Worked great, I also cut the hose coming fromt eh airbox down to 1 1/2" long and plugged that with one of them too. I also cut the smaller hose that comes from the throttle bodies at about 1" from the "T" and plugged that with a #8 screw. If anything, it sure makes it nice and clean under there now.
It's a free country brother
posted April 14, 2004 12:09 PM
Underwear Otis?
0.25310111045837 seconds processing time
