posted April 08, 2004 09:55 AM
Serious question, need advice My PCIII (USB) came today. I was looking at the list of places that are PC approved tuning centers and there is one just 20 miles from me, Brighton Superbike. I got on the phone and talked to a real nice fella there. They have their own race team for one, they also do tuning and suspension for AMA guys and are all gearheads. This fella certainly knew what he was talking about. So I asked him about bringing my 12 in for a tuning session on the PC and he said it was $300 and then went through all they do. Pretty impressive. The have an eddy current dyno and they set it up where the dyno controls the RPMS for the motor and they run it at different rpms and different throttle positions with the A/F tester in place to get the exact a/f mixture at each throttle postion/rpm then they create a map on the PC and then run the dyno again to check and make any adjustments. It takes two or three hours. He said they guarantee their work but assured me that it will be spot on perfect. Now you know how cynical I am to all the dickhead dealers around here. This place is not a dealership, they don't sell accessories or bikes, their main business is performance and suspension and he said they do not work on any bikes more than 5 years old. Do you think I should spend the money and take the bike up there???
posted April 08, 2004 10:43 AM
$300 seems a lil stiff - especially with the newer software that does much of their tuning work for them.
If they're gonna gaurantee their work then it may be worth it - I had my 01 mapped by 3 different people before North County Hyper Sports finally hooked me up.
172.3 on an 01 with K+N's, PC3 and full Ti Sato pipe.
posted April 08, 2004 10:58 AM
ask swft.. he owned his own dyno. seems about right for a full map. I see you sort of listened to me and got the USB. You crack me up ____________ What business is it of yours where I'm from, Friendo?
posted April 08, 2004 11:09 AM
Actually, fish, I didn't know the USB was what I was getting til it showed up. I called about it and they told me the USB is new and that's all that's going out now through them.
I really don't think $300 is too much to pay if I know I'm getting quality work and the map will be perfect. They said they will provide a printout of the all the information I need.
It's a free country brother
posted April 08, 2004 11:12 AM
Three hours is about right. And as to the amount of work to be done, that's still time on the bike, on the dyno and associated hardware. Most people don't know, but every run accounts for some wear and tear, usually to the O2 sensor and associated filtering system. So your cost pays for the tech (certified through Dynojet) the dyno, and the time. If it was just a DJ150 and you were throwing it up on there for a quick run, that's one thing. In this case you are paying for his training and the very best equipment.
posted April 08, 2004 11:18 AM
Edited By: VincentHill on 8 Apr 2004 12:42
Otis, my only question is, have you installed it and put in a map to see just how well the bike will run yet?
Try to think of yourself as having no money to spare (Not that hard nowadays). The first thing I would do is find a map that matches what you have and plug it in as see how well it works. Then read the instructions and try out the accelerator pump part of the new PC's
posted April 08, 2004 11:23 AM
ya right ninja.. he's lucky I didnt come there and put the boots to him ... instead he will just have to suffer through years of emotional abuse online instead... and there's nothing that can be done about that. punishment is punishment. ____________ What business is it of yours where I'm from, Friendo?
posted April 08, 2004 11:49 AM
The Pc3r has ignition timing. The USB has a feature that will allow you to have something like an accelerator pump action. You program it for how much fuel for how long at what rpms and throttle postion. That may sound like a lot, but think of it this way, you are at 2K rpms and rolling on the throttle. The bike hesitates for a second and the rockets away. You add 20% more fuel at 20% throttle for 1 second and you bypass the hesitation without changing the normal fuel economy of the bike and having loads of fuel at 0% throttle along with the flames and back firing.
Now I know that someone really knows and understand all about this, so please do not use this as an opportunity to show me up, Just explain what you know and we all can learn!
as a Deal's Gap tour guide.
posted April 08, 2004 12:02 PM
Very interesting...... An excellent thing if you ask me. I've tinkered with Holley Carbs for many years and I've learned that a pump shot is very critical. With Holleys it's squirter size, pump arm adjustment, and your cam that operates the linkage to the pump arm. All pretty simple if you have had a gazillion hours of trial and error on it. But this deal here sounds super simple to me.
I can tell you now that if it works as it should I'll be in the market very soon. Anyone that has firsthand knowledge with this please chime in.
swft?????
posted April 08, 2004 12:10 PM
From Dynojet's website, under the accelerator pump heading:
You can adjust: A) The amount of fuel to add, B) The number of engine revolutions during which fuel is added, C) The sensitivity of throttle movement under which the accelerator pump is activated
Interesting indeed..........
Swft, are you saying that the "USB" does not have a map grid system like the PCII and PCIII? ("0 to 100% throttle position and in 500 RPM Sections where you can change the fuel from + or - 1% to 45% fuel) or just the fact that it does not have aprovision for ignition timing?
posted April 08, 2004 12:32 PM
Otis....My Man,
If your coming this way anyway why don't you have Chris take care of it at Performance Psycle? No one will spend more time and he works 'til it's right. Dave in Daytona has had him write the maps for both his 12's and he takes care of everyone around here. He is listed in Dyno Jets directory for authorized tuners.
posted April 08, 2004 02:21 PM
Otis... you just starting to read the techincal posts on these boards???.....lol ____________
posted April 08, 2004 02:59 PM
Edited By: kcadby on 8 Apr 2004 16:05
The maps "look" the same but will come up as "incompatible" if you try to load a USB map into an older PC...or vise-versa...
The USB Software Window also looks diff., more like the YoshBox Window...Coool looking...
The USB...ALSO maps at every 250RPM instead of 500...VERY nice looking/straight fuel curve after mapping...
I don't think the pump is necesarily needed on ZX12s but is MUCH needed on the GSXR600-750s...
BUT!!! I have yet to see a USB on a ZX12 to try it...been wanting to see how well it works...
It will NOT be easy for a Dyno Tunner to set the pump correctly for "The Owner" though because there is no way of knowing when/how fast the owner turns the throttle...
DynoJet themselves told me this...
To answer the original question...
Sounds like they know what they are doing but...the TunningLink saves LOTS of wear and tear on yer bike because it maps the bike MUCH quicker than ANYONE can do it manualy...you didn't mention if they have a DynoJet dyno or tunning link???
I would NOT shy away from them just because they don't have TheLink though...
If they are a TRUE Performance shop (as stated) it sounds like they will do a good map for you...
By the way Steve Sir...(if you read this thread again)...I have talked the owners into doing a FREE map for YOU...because of the amount of work you have sent us...and the good words on SportBike
Sorry...this offer do NOT apply to anyone else at this time LOL
posted April 08, 2004 03:26 PM
uh.. not entirely true about the maps not being "compatible".. the software will upconvert on "old" map to a "usb" map... it will simply lack the addtional information that could be there because of the greater # of RPM steps. SO.. infact YES you can use an "old" map.. I have personally done this and tested it when I tested the USB unit last season.
posted April 08, 2004 03:34 PM
Thanks Kev. ____________
posted April 08, 2004 05:04 PM
Sorry for the not totaly correct info...
I have tried multiple times to load older maps into USBs and it comes up...not compatible on the screen...didn't continue to do anything else besides load a newer map
Only because the freekin software won't let you do ANYTHING to maps until you load one...
Although the TunningLink WILL let you map a bike when you click on NEW MAP
posted April 09, 2004 03:12 AM
OK, I installed the PC last night, pretty simple actually. I got my lap top out and installed the software and then realized that I left the damn USB cable at work! Doh! Anyway, I did load Ricks map (not a USB model) into the USB software and it worked fine, now whether or not that map will load into the actual PC I don't know yet, I will find out tonight.
I am for sure going to have a pro do this mapping for me though. If I can get Ricks map to work in the USB I'll ride it with that for a day or two and see how it is cause his bike has the same set up/pipe etc. as mine. BUt these folks do have the Dynojet 250 Dyno and the Tuning Link software so that is a plus.
Dan I thought about having the fellas down there do it for when I come down in may the problem is that I really don't want to take a whole day out to get it to them and have them do it when I'd rather be riding.
Vinnie, this accelerater pump thing you speak up sounds way over my head to deal with. I am not an engine expert by any means.
All times are America/Va [ This thread is 2 pages long: 12Next» ]
