BIKELAND > FORUMS > ZX12R ZONE.com > Thread: how f@#k do get in here?? pics NEW TOPIC NEW POLL POST REPLY
Otis
Captain Kickstand
posted March 31, 2004 04:29 AM        Edited By: Otis on 31 Mar 2004 04:32
How the F@#k do you get in here?? Pics
Took all the body work and stuff off last night to begin with some maintenence. I am going to be taking the front forks off and rear shock off and send them out for refurbishing, replace the spark plugs, add a PC and put on new tires and brake pads and now that everything is off, probably add steel braided brake lines. My question is replacing the spark plugs and while I'm at it, ripping out the clean air mod. Rick has e-mailed me pics of his motor with the clean air off but I have to say fellas, how the hell do you get hands in there to do ANYTHING. Check it out.
In this pic, do I need to remove, just try to push away all this crap blocking the way into the top of the motor?
Now there seems to be more room on this side of the motor, I can just move the throttle cables
And to get the rear shock off, how the hell do you get a wrench or socket in here to get the upper nut and bolt off this thing?
Or do I remove this nut from under the gas tank and pull the shock down?
He is the partially stripped bike after last night.
And holy crap! Look at the crap on the underside of my front calipers, that's not going to be fun trying to remove that. Any suggestions on a product to use?
It's a free country brother
Hells Dark Lord
living life, and loving it.
posted March 31, 2004 04:32 AM
let me know what you come up with on these problems Chris, I am gonna go through the same stuff next month. Hopefull mine will be done before DGVII, or I will be riding the little RR....
Otis
Captain Kickstand
posted March 31, 2004 04:42 AM
ONe other question. Those of you that have taken your rear shock off before, how did you support the rear of the bike to get it off??
Hells Dark Lord
posted March 31, 2004 04:51 AM
hang it from the rafters in your ceiling of your garage by the subframe Chris.... Or run a steel rod through the swing arm pivot and support in on 2 jack stands....
Getting that rear shock off might be easier if you take the inner fender off the bike....just a thought.....
Otis
Captain Kickstand
posted March 31, 2004 05:01 AM
Yeah, I was thinking about hanging it, thought there might be an easier way though. You know Jim, inthe manual, it says just remove the upper nut and then lift up on the rear of the bike and pull out the bolt. It doesn't say what happens after that though, as in, the bike will crash to the ground.
Hells Dark Lord
posted March 31, 2004 05:37 AM
lol....we hung mine from the rafters with tie downs when i pulled the shock off it, it worked well.....my buddy used the jackstand trick on his ZX9
REDX
posted March 31, 2004 05:49 AM
when I took mine off I supported the bike on a car jack. try simple green and a toothbrush on the brakes to clean them off.
busakillerzx12r
posted March 31, 2004 06:18 AM
I agree with REDX...Simple Green or Power Clean (the purple stuff) will take that shit right off. I imagine any engine degreeser will take that off...just my .02
_______________
BusakillerZX12R
wannabe
posted March 31, 2004 08:22 AM
The easiest way to support the bike to pull off the rear shock is to put a small jack under the oil pan. The bike will be slightly unbalanced, so just tiewrap the swingarm spools to the rear stand, and you'll be ok.
The is the absolute easiest way because if you use one of those screw-type jacks, you can jack it up a gnats ass at a time and easily get it to the point where there is no force on the shock bolts at all.
As for taking the top bolt off the shock...any way you can get up there....
your car is slow
Fuck Nitrous...Got Boost?
posted March 31, 2004 11:27 AM
As for the plugs.
disconnect all the wires from the left side (first pic)...and you will have pretty good access to all that crap.
Remove that ridiculous black plastic plate on top of the valve cover....should make for even more room. And get rid of the kleen air system if you havent already.
Once thats done..the little bendy tool kawasaki gave us in the toolkit makes short work of the plugs.
Do not taunt happy fun ball!
Otis
Captain Kickstand
posted March 31, 2004 12:35 PM
Thanks for all the advice fellas, I'll be tackling the plugs and fork and shocks this weekend. Still don't know how the hell I'm going to get that upper but loose on the rear shock though. There is no room for a wrench, I may have to take the upper rear fender off, which I really didn't want to.
Ninjaman12R
as a Deal's Gap tour guide.
posted March 31, 2004 12:38 PM
Simplify Jr.
Use a long extention and go through the hole on each side of the bike. (Where the 2 subframe spars are) That's how I'm gonna remove mine.
pdb1964
posted March 31, 2004 03:49 PM
I use Knight's Grez-Off to clean the crud off my bike, and the truck's engine. Works great.
Pauly
zrexpilot
posted March 31, 2004 06:34 PM
Put it on your rear stand first then put a car jack under the shock , lift it up, put jack stands on both sides with a pipe going through the bike just under and in front of the rear passenger peg brackets with the stands under the pipe, lower it and she'll rest there good and solid.
zrexpilot
posted March 31, 2004 06:36 PM        Edited By: zrexpilot on 31 Mar 2004 18:37
Put it on your rear stand first then put a car jack under the shock , lift it up, put jack stands on both sides with a pipe going through the bike just under and in front of the rear passenger peg brackets, with the stands under the pipe, lower it and she'll rest there good and solid. I didnt have any problems getting to that shock bolt, just use a box wrench
BA
posted March 31, 2004 08:30 PM
keep in mind that your shock is not centered on the bike man, she don't jack up perfectly straight!
posted March 31, 2004 08:37 PM
you guys are all Nuts!!! I have done this so many times. dont even screw with those bolts! unbolt the main top bolt.
Now to support the bike put a jackstand under the frame on the right side of the bike and then on the left side put it under the rear set. use straps to the rafters but only for an emergency fall off. once the bike is up off of the ground. remove the top lowering links bolt. and then the bottom bolt that goes through the shock and linkage. you shock will slide down and out easily.
Mad Mike
necro
My Grandma Is A Virgin
posted March 31, 2004 08:40 PM
That's why I don't like working on bikes.
posted March 31, 2004 09:13 PM
you didnt call me today otis.. call me on my cel.. like I said in the other thread.. "you're covered".
tuusinii
posted March 31, 2004 10:30 PM
Just did the same myself when my shock went to get new oils, seals and gas. I didn't have any trouble to get to the bolt holding the top of the shock - the inner fender was a little on the way but only very little and it gave up just enough. But I'd imagine as You have the top bolt allready at hands - just loosen it and You can have access to the top of the shock. And one note to getting to the plugs. I've removed that thing that hold the upper wires in the frame so I can just put them away. So I have to only disconnect the cam sensor, and the 2 wires for the cooler(sensor and power). And also that gray connector to that sensor I can't recall now. Then remember to unplug the wires to the plughats before removing them. I also usually remove that ram-air ducts and the trotthle cabals and choke cable. Put if You're only changing plug probably all of that dosen't have to be taken out. Next my work includes changing the gear change dogs and then the front forks and seals. It's now time to first seals and the bike has 75000 km! Not bad. Nice to see how the shock is know after rebuild? And when I'm trough - the summer is here and I can (finally) start riding...
Otis
Captain Kickstand
posted April 01, 2004 04:15 AM
OK, I got the plugs out. Actually, once I got all the wires and crap cleared away and the throttle cables moved, it wasn't nearly as bad as I thought, still tight under there for sure, but patience prevailed. I am leaving off the plastic tray and rubber mat. I pulled the plugs and they are bad, here is a picture or one, not a nice tan color like they should be, but what do I expect not changin them in 25K miles and running rich for half that.
I'm all set on how I'm going to get the rear shock off. I'll be working on that Saturday. Kinda in hold mode now waiting for the front pit bull adapter to arrive, hoping it shows up today.
I also just got an e-mail from Wilson about him doing my valve adjustment, I' going to see if maybe he come to the house cause I already have the top of the motor clear.
Fish, brother, I'm all set, thanks for the offer though.
Ninjaman12R
posted April 01, 2004 04:34 AM
Rich....
Damn that motor was running rich Chris!!! Of course nobody knows that as well as I do.
See grasshopper, I told you once you got all the shit out of the way it wasn't so bad. (dude from The Waterboy voice) You can DO it Chris!!!!
Otis
Captain Kickstand
posted April 01, 2004 04:51 AM
I'll tell you Rick, putting more lights in my garage sure helped. I have 12 4 foot banks of lights in there now and it's bright as shit. Kinda like having the sun in the garage. Makes working on projects like much much easier. A neightbor stopped by at about 8 last night and laughed saying he thought a surgery might be going on in there it's so bright. I looked around at my bike in pieces and parts all layed out nice and in order on my workbench and said, yeah surgery IS going on.
Ninjaman12R
posted April 01, 2004 05:31 AM
Fuckin' Vegas or Detroit?!?!?!?
Damn son, you paintin' cars in yer garage now???? Fucking 12 banks of 4' lights. Geesh...... I am actually about to add more lights to my garage. It's lit about as well as your average morgue right now. I'd be a lost sumbiatch with out my drop lights. (and flashlights )
posted April 01, 2004 05:36 AM
hey otis.... just to let you know, since I happen to know quite a bit about the 12Rs and the bits etc... dud .. you blew it... i had you hooked up ... but whatever...
so enjoy and no harm done, but i had you hooked up way more than you could ever be now.
0.31869101524353 seconds processing time
