BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Chain Lube NEW TOPIC NEW POLL POST REPLY
pdb1964
posted March 29, 2004 08:41 PM
Chain Lube
What are you guys/gals using for chain lube? I was using the spray stuff but I found the stuff really messy and a pain in the arse to clean off of everything it flung itself to, especially in the drive sprocket area.
I now use heavyweight gear oil and even though I might have to lube more often and it does fling, it is a lot easier to clean.
Pauly
posted March 29, 2004 08:59 PM
90W should be fine!
ZXLNT
posted March 30, 2004 02:27 AM
PJ1 Blue Label, AFTER I get back from riding. That way the chain is still warm allowing the lube to penetrate and the solvent to evaporate...
Hells Dark Lord
living life, and loving it.
posted March 30, 2004 02:28 AM
I am with ZXLNT on this one......
posted March 30, 2004 07:34 AM
Done at this time by spraying the lube on the "Inside" of the chain while it idles in 1st.
I use Alisyn. It was developed by an Aero Space engineer in Columbus Ohio and does not let much dirt attach to the lubed chain. Now LP and all major places sell it. Warning, you must shake the Hell out of the can before use.
Prior to this, I was using Chain wax which was fine until it rained and on a trip. I heard the chain start to get loud about every 50 to 100 miles on that trip and stopped using it right after that!
necro
My Grandma Is A Virgin
posted March 30, 2004 07:49 PM
I can't remember, but I use a lot of it.
tuusinii
posted March 30, 2004 11:13 PM
Shell dry chain lube - it reallyl is dry and dosen't get things dirty... Also cheaper (atleast here) than Castrol Chain wax.
pdb1964
posted March 30, 2004 11:22 PM
Thanks for the info
Pauly
Hells Dark Lord
posted March 31, 2004 04:30 AM
chain wax sucks.....
pdb1964
posted April 01, 2004 01:17 PM
I think I wll stick with the 90W oil for a while.
Pauly
busakillerzx12r
posted April 01, 2004 01:39 PM
90W for me too...easier to clean by far....
_____________
BusakillerZX12R
Hells Dark Lord
posted April 01, 2004 03:11 PM
only problem with using 90W, is tha tlike all oils it attracts and holds dirt and grime. It is a very good lubricant, but after a few miles all of the dust and grime from the road sticks to it and then start to works its way into the chain....if you use it, make sure you clean and re lube the chain regularly.....
your car is slow
Fuck Nitrous...Got Boost?
posted April 01, 2004 04:26 PM
Ive used this stuff for awahile...although I dont ride much anymore
It cleans the tires good from the overspray!
Do not taunt happy fun ball!
posted April 02, 2004 07:17 AM
Silkolene makes excellent products
morrisjl2
posted April 02, 2004 09:24 AM
I found this on zx12r.org about wd-40. I use it to clean and then about the first 100-200 miles of riding or at least till I get back from my first ride when the chain is good and hot and then Castrol chain wax. Just my 2 cents.
http://www.zx-12r.org/phpBB2/viewtopic.php?t=23557&highlight=chain+wd40
  Ignore this member    Click here to send morrisjl2 an AIM message.
morrisjl2
posted April 02, 2004 09:27 AM
The site again... [url]http://www.zx-12r.org/phpBB2/viewtopic.php?t=23557&highlight=chain+wd40[url]
morrisjl2
posted April 02, 2004 09:28 AM
Damn, how do I get this on here?
ynot
Naaaaarf
posted April 02, 2004 09:40 AM
Here you go mo
But Brain... Where are we going to get enough Caramel and a Cherry big enough to cover the Alps?
Hells Dark Lord
posted April 02, 2004 10:31 AM
wd-40 for lube, um NO.....not me....I can see using it to clean the chain, but not to lube it......JMO
castor
posted April 06, 2004 03:32 PM
Bel Ray Super Clean....
Awesome
C
0.26679682731628 seconds processing time
