BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Is this right? NEW TOPIC NEW POLL POST REPLY
jessz1
Half the wheels, twice the fun
posted January 04, 2002 06:46 PM
Is this right?
Put my muzzy clutch and basket in and this is what I end up with.
I have the arm pushed forward to take up the slop in the picture. It is so far back my cable is at the end of the adjustment. Have the cover off now and everything looks good. What do you think?
I'm never satisfied.
  Ignore this member    Click here to send jessz1 an AIM message.
posted January 04, 2002 09:22 PM
adjust the cable all the way the other way, and it should be fine.
mad mike
jessz1
posted January 04, 2002 09:54 PM
It's not the cable adjustment I am worried about.It is the angle of the arm. To far away. Makes me wonder if I got the cover stabbed on right.
SpencerCyclecom
posted January 04, 2002 10:41 PM        Edited By: SpencerCyclecom on 4 Jan 2002 23:17
jes,
Yes It looks Okay. Here is a pic of one we did last week.Same thing--just adjust the cable as per instructions
Doug
SpencerCycle.com
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
posted January 05, 2002 01:08 AM
Jessz1
Yours looks like it makes a bigger angle than Spencers, but I went and looked at mine and IT LOOKS JUST LIKE YOURS. My "expert opinion " is that its fine.
jessz1
posted January 05, 2002 07:57 AM
It looks like the angle of the bracket that holds my cable to the case is at a different angle than spencers. Hmmmm....
madmike
posted January 05, 2002 09:59 AM
Hmmm...
dude I think you might be right? Ill check mine in awhile, could your bracked be upsidedown?? man that is weird.
mad mike
jessz1
posted January 05, 2002 01:31 PM
Here is another picture. My lever is to far back causing the cable to be at a wierd angle. Everything looks good and works fine. Strange...
ZX12Girl
Adrenaline Junkie
posted January 05, 2002 10:33 PM        Edited By: ZX12Girl on 5 Jan 2002 22:34
Here is mine!!
I went out in the garage and took a picture. I have the Muzzy clutch & basket as well. Installed by my Hubby!!! I do not have as much of a bend as you!!!
Dunno???
EastBayDave
posted January 06, 2002 08:07 AM
Very interesting. Anyone tried the 01' lever on a 00' ??? I hear the lever is "longer" for more leverage?
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
posted January 06, 2002 10:10 AM
anyone want to buy a 01 clutch actuator lever?
I tried it, and still have it in my garage (not on the bike) if anyone would like to buy it (cheap). I didn't like it because the pull was harder. I have a Muzzy kit and basket.
It was hard enough to make me curious, so I dug around my fishing gear and pulled out a spring scale I use for weighing fish: I used the scale to pull on the clutch (hand) lever with the stock00 clutch actuator lever installed, and then later with the 01.
00 lever = 13.5#
01 lever = 16.5#
go figure. I don't remember how many Muzzy springs , 3vs6, I was running then, but spring set up was same in any case.
BlackMandingoWarrior
posted January 06, 2002 01:29 PM
Hey Angie.....
How'd you do that??? Take the picture on the 6th and post it on the 5th???
BMW
The QuickSilver Ridin MoFo
BFLY
posted January 06, 2002 02:37 PM
u need to recheck that clutch dont let that go you will chew up the pull pin trust me on this one i know frist hand just ask blastic.
  Ignore this member    Click here to send BFLY an AIM message.
ZX12Girl
Adrenaline Junkie
posted January 06, 2002 05:18 PM        Edited By: ZX12Girl on 6 Jan 2002 17:21
BMW
Ancient Chinese Secret!!!SSSShhhhh!
Actually - I took the picture and posted it on the 6th....Then I edited the post the day before that (5th)!!!! Don't have a clue on that one!!!
jessz1
posted January 06, 2002 05:53 PM
Already had it apart and checked the basket/ hub installation. Pretty hard to mess that up. Cover goes on OK also. Hoping Rob or Doug will post there .02
harryzx-12
posted January 07, 2002 02:01 AM        Edited By: harryzx-12 on 7 Jan 2002 17:25
Clutch pack stack height
Maybe that's your problem.Take a picture of your basket through the oil fill hole and post it.
kcadby
posted January 07, 2002 03:02 AM
If you can...please take another picture through the oil fill hole that...shows the basket and pressure plate???
I'm curious what the stack height looks like...got any with the cover off???
(this is a stock basket)
Here's the 00 and 01 Levers...
...The Release Rods...the one on the left was in the motor with the "damaged 00 lever"...note the rounded edge on the close side of the tip...
jessz1
posted January 07, 2002 07:52 AM
I am getting ready to go to work but I will pull the cover off tonight if you need to see whats going on better. Looks like the pressure plate is in the same place as the one in your pictures above Kevin.
jessz1
posted January 07, 2002 05:23 PM
I was wrong. My stack height is short for some reason.
jessz1
posted January 07, 2002 05:26 PM
Here is another picture. What causes this. I have zero miles on this clutch.
SpencerCyclecom
posted January 08, 2002 01:07 AM        Edited By: SpencerCyclecom on 8 Jan 2002 01:07
You guys and gals can view all the pics we have on installation of a Muzzy clutch kit on our website.
www.spencercycle.com
Just click on the "HOW TO' link and then "MUZZY CLUTCH KIT" link.
Just a article on how to install the kit.
Doug
SpencerCycle.com
1-800-510-1945
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
posted January 08, 2002 01:37 AM
Jessz,
my stack height is the same as yours. With new plates the edge of the pressure plate is just about even with the top of the basket. If you have a problem so do I. However, my clutch works great...
Jessz,
jessz1
posted January 08, 2002 05:43 AM
I'm sure I have everything together right. It's not rocket scientist stuff. The stack height concerns me though because of the angle it puts my clutch lever at. Also not to much wear and it will bottom out. Wheres Doug at? I'd like to hear his coment on this. Is it differences in Kawi's tolerences? Or Muzzy's?
jessz1
posted January 08, 2002 03:17 PM
Bumpen her up. Where is Kevin? Kevin, Hello? What is your thoughts on my stack height? One or two millemeters and it will bottom out. Should I worry? Or run it.
0.25925922393799 seconds processing time
