BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Computer Question NEW TOPIC NEW POLL POST REPLY
necro
My Grandma Is A Virgin
posted March 24, 2004 04:11 PM
Computer Question
Where in the BIOS does one set the memory from single channel to dual channel?
BA
posted March 24, 2004 07:48 PM
hmmmmm. Going purely from memory because I now have an Abit brand board,.....I really think that there IS NOT a particular BIOS setting for that feature.
According to the Asus manual, as I recall, you certainly had to have your two 'sticks' of memory in certain slots. Either slot #1 and #3, or something to that effect. I used 1 and 3 because it allows for air-flow between them for cooling purposes so those are stuck in my head.
When your PC boots up, and you see the "DOS" screen with the black background and white letters mentioning all kinds of stuff, it will say "Using Dual Data Rate memory" or something very close to that.
I recall it being one of the first things to pop up, like within the first 10-13 seconds.
necro
posted March 24, 2004 08:14 PM
I have the memory stick in slots 1 & 3.
When it boots up, it says single channel.
slug
Out in search of my mind...
posted March 24, 2004 08:42 PM
check the motherboard manual, it will tell you which slots to put the ram in
if the ram is there, then most likely the ram itself isn't passing the 'tests' requried to go dual channel
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
necro
posted March 24, 2004 08:54 PM
Damn.
posted March 24, 2004 09:44 PM
I woulda thought it would be slots 1 and 2
EastBayDave
posted March 25, 2004 06:45 AM
took da words right outta my mouth...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
phingersniffer
posted March 25, 2004 12:25 PM
for the asus a7nx, you need to use slots 1&2. do that and
sit back in awe of the 0.5% speed increase the dual channel will
give you.
The number one enemy of progress is question.
bossman12r
posted March 25, 2004 12:49 PM
You know the ram much be match ram most of the time to work also. My MSI board had to have matched ram. I have 2 sticks of 512 and it just see 512 but in phy memory is says 1 G
gen 4 zx10 is fast
BA
posted March 25, 2004 03:10 PM        Edited By: BA on 25 Mar 2004 15:11
you guys are funny.
here's the manual online.
http://usa.asus.com/support/download/item.aspx?ModelName=A7N8X
look at page 1-7. it tells you where you can put your memory for Dual DDR function. Slot 1 and 3, slot 1 and 2, etc.
I had the board, I used slot 1 and 3, and it worked.
Are you sure your memory is identical as mentioned above? (I've forgotten from the older thread) It is required to be identical.
look at Asus board and they can tell you if it's "approved" or not.
PS. I think you'll get a hell of a lot more than a .5% increase in memory speed. I sure hope that was a joke, or typo.
Just use any memory bandwidth test to verify, I did.
necro
posted March 25, 2004 04:23 PM
The memory is identical. Two crucial.com sticks of .5 G.
I have them in slots 1 and 3.
necro
posted March 25, 2004 04:30 PM
Does ASUS A7N8X-X support dual channel memory technology?
Summary : No. Within NVIDIA chipset specification, A7N8X-X supports single channel memory mode. If you want to have dual channel memory support, please purchase A7N8X, A7N8XDeluxe, or A7N8X-VM.(Knowledge Base)
BA
posted March 25, 2004 09:53 PM
that's kinda fooked up brother!!!
can you try the 'beaten dog' look at the place where you purchased it? Maybe get an exchange where you then pay the difference?
the A7N8X board can be had for like $88, only $13 more than the 'X' version!
phingersniffer
posted March 26, 2004 11:48 PM
The 0.5% increase was a "seat of the pants" feel.
I traded in my A7N8X Deluxe last month. I tried single and dual mode
and could not tell the difference in use.
Ive got a shuttle sn41g2 with a nforce 2 board dual channel. seems the
same as the asus for peformance. I just like the tiny box. 12x8x7.
necro
posted March 27, 2004 09:21 AM
You know what this means? Don't you.
I am forced to fill the last slot with a stick of 1 Gig...
posted March 27, 2004 09:23 AM
Go for it! Hey, just bought the new Sony 8X DVD +- R/RW drive. Gonna go stick it in the server right now.
BA
posted March 27, 2004 03:16 PM
you serious NEC'? If you are, that's cool. Just put the big stick in slot 1, as that will be what the cpu uses first. Whats the price difference between that gig stick and the "dual DDR" motherboard? The mem. will be more right?
necro
posted March 28, 2004 05:39 PM
The memory is more but less hassle to instal.
Thanks for the advice about where the 1 gig goes. I was wondering about that.
0.23579597473145 seconds processing time
