zx12richard
The Green Monster..
posted March 15, 2004 01:08 PM
800 hp Viper VS Busa's and 12...
Found on another board...
Just returned from a great day out. Met with BigGar (with Flea as pillion), Rex (on a BMW), BiggerDanno, NickSlick and of course, ViperBusaOwner with his Supercharged Viper.
I'll start by saying that I commend everyone for coming at this with a good spirit - more camradarie than competition. Even with Nick there, there was only a smattering of ego and talking smack. Full respect to Manny for coming out and running with us. We all had a blast.
We had a nice warmup ride tooling through the twisties and the mountains on our way to the top secret closed course high speed testing grounds.
We then set up four cameras, two in Manny's car - one pointing forward, one pointing back, one in the cockpit of Gar's stock Busa (Akro pipe, small box mod, no PCII) to use as a chase camera, and then one more on the side of the course to follow the action from the side.
The Viper was filled with 100 and something octane gas and it was off to the roll-ons. Temperature was from high 70's to low 80's, I think. We were running into a 10-15 mph headwind, and the air was fairly dry. Traction was never an issue for any of us.
The car is a Supercharged Viper fresh from Levin's shop in FL. It was dynoed there before it left and made 886 HP. Upon arrival in CA, Manny took it to be dynoed, but only got a torque reading as the operator couldn't get an accurate HP number. Torque was in the mid-700s. According the Manny, usually with a supercharged Viper, HP is higher than torque, so the car is probably putting out HP in the 800+ range. He has aftermarket body work on it with an air splitter on the front and a wing on the tail, which are both good for keeping the car planted, but perhaps not top speed. Manny (I estimate weighs in a little over 200 and he had probably another 40 pounds of stuff in his car.)
Danno, with his completely stock Busa ran three times with the Viper first. Danno had a PCII connected with a map he used with his NO2 kit on it, so he was a bit rich up top. Afterwards, he realized he should have just disconnected the PCII. Dyno rating for his Busa he thinks is about 150. Danno in gear weighs about 210lbs.
NOTE: Every run that was made was on a completely empty road. All riders wore full protective gear. There are generous shoulders, a nice surface and unlimited visibility on our flat, arrow-straight course.
(The following recount is from my memory, which should be pretty good. However, if any of the guys wish to weigh in and comment, please do. Nick absconded with the four videotapes and went to his boat. Tomorrow night he'll be editing video. He wanted to make sure he was the director, but I'll be the technical advisor on the video, which should be posted by Monday night. Be patient.)
Run 1. They started from ~45mph with Manny signaling go by beeping three times. Danno didn't hear the beeps, so Manny got a slight jump, then Danno reeled him in and passed. Then as the speeds were getting up near 160, the Viper began to pull the Busa with Danno shutting down a little before Manny.
Run 2. Starting procedure changed to Manny extending his hand out the driver's window to signal a go. On this run the start was awkward since Manny and Danno were thinking they were starting at different speeds. Manny thought they were running from 50mph; Danno thought they were running from 75mph. Danno pulled a little lead, but then it evened out again at high speed.
Run 3. Rolling start from ~75mph. This time Rex rode along with Danno and filmed from the passenger seat. This was a VERY even race. The footage is excellent. They each surge ahead of one another as the shifts happen.
BigGar was up next on his Busa which has an Akro full system exhaust, a small box mod and not much else. With a PowerCommander a while back, the bike dynoed at 167. Without the PC, Gar estimates the HP at a little over 160. Gar suited up weighs in at about 280lbs.
Run 4 Manny had determined that third gear close to 3500 was the optimal launching setup, so they ran from that speed. With the pipe set up on Gar's copper Busa, he was able to slowly walk away from the Viper.
Run 5 Similar result to the first race with Gar with Gar walking away.
By this time Nick was about to explode if he didn't get the chance to run against the Viper. The outcome was a foregone conclusion, but Manny was game for the challenge and stepped up to the plate like a true gentleman.
Now, for the two people out there who don't already know, Nick's bike is a big bore 1397cc Busa with cams, a lightened and balanced crank, titanium valves, springs, ported head, (and some other stuff) assembled by Carry Andrews of HyperCycle (he runs a factory Suzuki team). It also has a 20 shot of Nitrous to top that off. Earlier this week it dynoed at 197 w/o gas and 215 with the juice. His bike is about 100lbs lighter than stock with a liberal amount of carbon fiber on it. Nick weighs about 255 in full gear. Of course, Nick ran with Nitrous.
Run 6. Nick pretty much walked away from the Viper. He opened up a good lead and kept it. Even a low grade turbo with mid-200hp power would have made the race even more of a mismatch.
Lastly, I lined up with Manny on my ZX12R. My bike has a Muzzy big bore stroker motor displacing 1367cc's. It has a liberal amount of carbon fiber on it as well, making it quite a bit lighter than stock. The last time it was dynoed, it put out 186 on the rear wheel.
Run 7. Manny liked the 75mph rolling start, so we rolled on from that speed. This time, I lined up about 4 car lengths behind him rolling at the same speed until he gave the signal. When he dropped the hammer, I immediately gained ground on him and passed him quickly. As the speeds increased, the gap may have stopped growing. Manny felt he had his best launch and ran it up to the highest speed he'd run yet (~180), but didn't seem to gain ground before we shut down.
Afterwards, we all enjoyed lunch and reviewed the video taped on the 4 cameras we toted into a little Mexican restaurant. One of the bus boys approached asking about the bad-ass Viper parked with out with the bikes.
All in all, it was a great day. Thanks much to Manny for coming out to join us. Let us know what the dyno number is on your car in that configuration with that fuel.
Video to follow. It will be a good one!
zx12richard
The Green Monster..
posted March 15, 2004 01:09 PM
Video.....
http://www.chatstat.com/VIPER2.wmv
supraman95mb
posted March 15, 2004 01:42 PM
Edited By: supraman95mb on 15 Mar 2004 13:50
Thats pretty sweet.
There is a bunch of guys challenging the supras on their busas. Of course these guys here look like they were cool and having fun. The busa guys were talking all kinds of *&$^ about how their busa is faster than the supra. I mean come on. My supra has 700 to the wheels. Weight ratios are a big deal. My 12R stock could hand my supra its A$$.
Then there is this one guy who says he will race him for money, his turbo busa vs. the supra.
OK I have a fast car, but even if I didnt I would not say "well I can beat you on my bike" like that is hard to believe!! Unless your riding something really slow.
Here is just one of them but there are tons more.
http://supraforums.com/forum/showthread.php?s=&threadid=176718
02 Stroked 12R
95 Supra Single Turbo 750+ hp
supraman95mb
posted March 15, 2004 01:51 PM
you may have to copy and paste the link into your browser!
02 Stroked 12R
1bad12r
posted March 15, 2004 02:38 PM
Dam, I guess we just thought we were the fastes on the road.
768 Ryderz
posted March 15, 2004 02:42 PM
Nice writeup! Thanks!
posted March 15, 2004 03:33 PM
very cool, but I tell you what If My 1361 only put out 186HP, I would be pissed!!!
also how do you get 1367?
I bet the guy in the viper get's more chicks.......
deathpulse
posted March 15, 2004 03:36 PM
OK - that was a cool video . Congrats to all participants!!!
BA
posted March 15, 2004 04:42 PM
ditto,.....nice write up. I love hearing stories like that...I never get to see that stuff around here......
zx12haitian
:APB: BLACK MAN SPEEDING
posted March 15, 2004 10:46 PM
nice one
Your bike must be really fast b/c you were flying when i passed you
busakillerzx12r
posted March 16, 2004 01:22 PM
vid won't work for me.......
BusakillerZX12R
_____________
Don't think your gonna roll me on your liter bike....cause your not, you little punk kid!!
BA
posted March 16, 2004 02:10 PM
perhaps a Media Player update is needed Busakiller?
you can get it from www.microsoft.com of course, it's gonna be about 10MB+
