BIKELAND > FORUMS > ZX12R ZONE.com > Thread: doug meyer, a few questions you?? NEW TOPIC NEW POLL POST REPLY
posted March 13, 2004 12:58 PM        Edited By: VincentHill on 15 Mar 2004 13:37
Doug Meyer, A few Questions for you??
What is the "Part Number" of the JE STD Size Piston Kit?
To keep the same compression, how thick of a Base spacer do I need to use? (If so, do you have a spacer that thick?)
You said that you were out of them, when will you have more? DM, are you watching the board this week?
posted March 17, 2004 01:07 PM
Heard from DM The part number for their STD High COmpression Pistons is 0007-00133, ZX12 High Compression Piston Kit. List price is $795.00. I still am not sure what the combustion volume change is with these pistons with either a 2 mm spacer or 1.6 mm spacer. I plan to check a little more and talk to JE to see what they have made to cover what I am looking for. I do not know enough to have Arias make a set of pistons that will turn out to be what I want and plan to check with MTC before I make the purchase.
Please understand that the Piston is the most important thing in the combustion chamber (At least to me between the way it is made, The shape on top, and the rings it uses). The second thing is the Head Gasket, because no matter how everything else works, if it lets go, you still have nothing! We have all heard how "High COmpression" makes NOS work better, well to me, it also make it blow up easier also!
0.2234411239624 seconds processing time
