BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Muzzy clutch... NEW TOPIC NEW POLL POST REPLY
jessz1
Half the wheels, twice the fun
posted January 02, 2002 04:27 AM
Muzzy clutch...
I just installed my muzzy clutch and basket. I noticed my cable adjustment was all the way tight. Makes the cable pull at an awkward angle at the clutch puller on the engine. Anyone else have this problem?
  Ignore this member    Click here to send jessz1 an AIM message.
silver01bullit
on here too much
posted January 02, 2002 09:01 AM
You need to have some play at both ends of the cable (the lever and clutch case). This ensures that the clutch is grabbing as much as it can and it's not slipping. With tension on the cable, the clutch may be slipping under hard load
  Ignore this member    Click here to send silver01bullit an AIM message.
posted January 02, 2002 11:23 AM
Make SURE that the puller actuator is properly fitted on the puller. The angle is different but not radically so. Start over and check everything.
Doug
jessz1
posted January 02, 2002 08:07 PM
Whats the best way to get that shit all stabbed back together?
RAC4IT
Bergie
posted January 03, 2002 12:16 AM
Starting Over..
Like Doug said sometimes the best trick is to start over and double check everything. I normally leave out the two bolts that retain the clutch cover cable holder until last that way everything slips together easier. Starting with the clutch adjustment set in the middle position on the bar I then begin adjusting the cable at the clutch cover until I get the proper feel. Sometimes a trip or two around the neighborhood is necessary to get everything "seated" proplerly and a minor final adjustment will be required after the first couple miles. Hope this helps...
jessz1
posted January 03, 2002 05:56 AM
It feels OK. I just don't like the angle that my cable is going to the lever. Hope it doesn't prematurly wear out my cable.
0.22930788993835 seconds processing time
