BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Battery Tray NEW TOPIC NEW POLL POST REPLY
Bikelover
posted December 31, 2001 07:18 PM
Battery Tray
Well I gave up on the weather today with the temp 15 Degrees F, I removed the battery for the first time since new. Man did I get a shock. The positive wire just below where it connects to the battery had been rubbing the frame. The positive lead leaves the battery and goes down then does a U turn up to the relay box. In the verticle section just below the battery, the lead had been rubbing on a sharp edge in the frame. The insulation was almost worn through to the wire. Just a few more thousandths and it would have been disaster. Of course, this is before any fuses, so it would undoubtedly have resulted in a fire. I'm glad it got cold when it did.
Check you wires, especially if you have never had the battery out.
posted January 01, 2002 01:01 AM
I HATE the battery tray.... if I have my way... with a little brain werk I will eliminate that thing and relocate the battery under the seat where it should be......... leaving a nice viewing port right through the middle of the frame!
0.23115992546082 seconds processing time
