jessz1
Half the wheels, twice the fun
posted December 31, 2001 11:14 AM
TPS setting.
On my power commander my TPS is at 0 at idle and at 102 at 100% Is this normal? Thanks.
I'm never satisfied.
posted December 31, 2001 11:56 AM
You have to use the "adjust TPS" setting before you upload you map (while the bike is connected to the computer..) Make sure your TPS is in it's stock factory setting (ie: you didnt adjust it manually... if you did reset it to it's factory values first)
jessz1
posted December 31, 2001 02:12 PM
What is the factory values?
KawRider
posted December 31, 2001 03:57 PM
TPS Setting?
Why would it matter that you set the TPS to the factory setting before Calibrating the Throttle Range with the PCIIIR? If the TPS is optimized for the sweet spot, it should be good.... and the PCIIIr only needs to know where the throttle grip is... which is done by calibrating it?????
Forgive my ignorance.
Tim
Black ZX-14
posted December 31, 2001 04:16 PM
That is a question to be directed towards Doug Meyer or Tearnitup .... these are their instructions
posted January 01, 2002 07:55 PM
factory values someone, pleeze
Phil
posted January 01, 2002 08:25 PM
Edited By: Phil on 1 Jan 2002 20:30
jessz1, factory setting is 1.084~1.086 vdc output voltage.
"Look at Dad, trying to look young again."
jessz1
posted January 02, 2002 04:14 AM
Thanks buddy!
Phil
posted January 02, 2002 03:56 PM
Edited By: Phil on 2 Jan 2002 15:56
PS,The shop manual states engine warmed up thoroughly and idle speed set to 1000rpm then measure with engine off.
