BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Is this site hard to read? NEW TOPIC NEW POLL POST REPLY
EastBayDave
posted December 31, 2001 07:24 AM
Poll Question:
Anyone having trouble reading the text on this site?
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
Poll Results:
 12 votes (80%)
No problem
 2 votes (13%)
Slightly small text
 0 votes (0%)
VERY small text
 1 votes (7%)
I can't see it at all, old fart, glasses, etc.
 0 votes (0%)
Other? (specify)
EastBayDave
posted December 31, 2001 07:28 AM
No offence guys; just hard to read one of my favorite sites!
I have to put my nose on the screen almost. It's the only site I have a problem with; even other Blazeboards are ok so I'm a bit mystified as to why I'm the only person to have a issue with this one? Maybe just an old fart w/bad eyes? Hmmm....
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
posted December 31, 2001 09:45 AM
What browser and version are you running? I have no problem at all ...
EastBayDave
posted December 31, 2001 11:11 AM
running IE6.0
Don't know what the problem is other than getting old, fading eyesight. I combat that on other sites by using the "Largest" text size available in the "View" selection part of IE...
Suggestions?
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
posted December 31, 2001 11:58 AM
Theprobs you are having are a prob with IE 6.0 .... freek is fixing it.. .if you use 5.5 the displayed fonts are correct.... not so with 6.0 ... 6.0 also wont display flash files withing threads....
we hate Microsoft....
redelk
Please... speak to the hand.
posted December 31, 2001 12:04 PM
Naw, your not the only one....
There are a few things I've noticed and this might help you out...
1. The font is slightly smaller on Netscape 4.7 then it is on IE 5.5. Also, Netscape show all the various font sizes in the posts as the same size. I suspect the Mozilla browser has corrected this, but I doubt if it looks any different then IE 5.5.
2. You might want to check the resolution setting of your monitor. Normally, 600x800 is fine, unless you play a lot of PC games or do a lot of graphical work. Some say that even photographs don't look any better at resolutions higher the 600x800 (this is always up for debate).
3. You might want to check the default font size of your browser. I don't know how much of a difference this will make (if it'd make any difference at all), but it'd be worth trying out.
-Ernest Hemingway
EastBayDave
posted December 31, 2001 01:31 PM
Duh...I just upgraded from 5.5 to 6.0...that explains it...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
EastBayDave
posted December 31, 2001 01:36 PM
Yea I do some graphical things from time to time, so settled on 1024x768 (32bit True Color) as it seems to work best. I changed to 800x600 to try it, & the end of sentences were cutoff on the right side of screen/no movement elevator available. Weird...
Default size is 10 pitch; I've been able to change the Font type around a bit; which helps some, but not enough. (Courier is better than Times, etc.)
I'll keep playing around a bit... Think the IE6.0 is the root of the problem... Probably a hidden switch somewhere in here...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
frEEk
posted January 02, 2002 12:04 AM
the wierd part in all this is that we use CSS to specify font sizes, so they are spelled out directly in point sizes, unlike non-css pages which just say size=1 or 2 etc, leaving it a relative font size. i'm not sure if this is really something i can fix unfortunately. u rnt the first person who has had this problem. i have a coupel possibilities in mind, but they r iffy. will try to get it so u can choose a size set as soon as i get a chance. but remind me every so often, cause i aint got a good memory.
posted January 02, 2002 12:07 AM
the problem is that it is changing the FONT althogether... it is changing it to TIMES, which is far harder to read in the font sizes we use.. that is the problem... it is calling up a difff font in 6.0 ... not diff sizes..
0.24096488952637 seconds processing time
