BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Power commander question... NEW TOPIC NEW POLL POST REPLY
zx12richard
The Green Monster..
posted February 03, 2004 05:47 PM
I want to get something to carry with me for swapping maps... Laptops too big...
Now I know nothing of palm pilots or any of that stuff.. SO model numbers or stuff appreciated..... I want a cheap way to swap maps is primary funtion and set throttle position if possible... Thanxxx in advance.......
vozizm
Got Nothing Witty To Say
posted February 03, 2004 05:50 PM
NOS BOY...
I had a Palm xII i think...serial port... all i was able to do was change maps..... had to alter maps on puter then load to palm then to pc3r..
posted February 03, 2004 07:22 PM
yeaper.. the palm ull do ya.
zx12richard
The Green Monster..
posted February 03, 2004 09:39 PM
When changing maps do you lose your tp setting?????
What kinda palm pilot thing???? I know nothing about them... Looking for a cheap version...
Oh and thanxxx guys..
posted February 04, 2004 03:25 AM
Why would you lose your Throttle Position setting?
zx12richard
The Green Monster..
posted February 04, 2004 03:58 AM
I don't know thats what I am asking???? I don't know shit about a PC3R other than I am on my third one.....And how to install them.... Never had a laptop to use the software till very recently...... So its a learning process for me... I just assumed when you loaded a new map you would have to do thr tp to....
posted February 04, 2004 04:59 AM
The 3 and 3r work virtually the same ... sans the extra ground wire.
zx12richard
The Green Monster..
posted February 04, 2004 05:16 AM
Is the actual product actual name the Palm pilot???? What I am looking for is the cheapest model that will swap maps???
posted February 04, 2004 05:22 AM
Yeah... about $100 at any electronic retailer.
Tearinitup
VP Code Monkey
posted February 04, 2004 08:15 AM
PalmIII, PalmV, PalmVII, Palm m505, and I think m105 are all useable versions of the palm. I personally used a PalmIII, a PalmV and a Palm m505 when I was writing it.
The Handspring Visor is cheaper but DOES NOT work. The serial electronics are not part of the unit so without the cradle plugged into a computer nothing works.
You can pickup a used PalmV for 50 bucks pretty easily. That is what I would recommend since I have the most testing on that model. You are likely to have the least amount of problems.
Tearinitup
VP Code Monkey
posted February 04, 2004 08:17 AM
Also... Once you have your TP calibrated for your bike you don't have to send it anymore unless something physcally changes on the bike. So setting it once should be good.
zx12richard
The Green Monster..
posted February 04, 2004 10:07 AM        Edited By: zx12richard on 4 Feb 2004 10:18
Thanxxx thats the things I needed to know... Going to look for a palmV...
When installing a map from Palm does it bring up the screen like when you do it from laptop????? Or how does it work???? I am just learning PC software... It was kind easy...
posted February 04, 2004 11:20 AM
will the palm werk with the pcUSB?
BTW... where' my ignition advance ?
fag.
posted February 04, 2004 07:05 PM
If your palm has USB capabilities ol Fishy.
posted February 04, 2004 09:59 PM
I want the answer from "the man" (that wouldnt be you this time, turbo ) ... so fess up there Tearnitup!
Tearinitup
VP Code Monkey
posted February 05, 2004 03:45 PM        Edited By: Tearinitup on 5 Feb 2004 15:48
No. We are exploring options for doing this currently.
Coming. You might have one sometime after I have one.
Fag.
JoshDunn
posted February 23, 2004 08:11 PM
Does anyone have a 3r usb yet? I need a PC3r within the next month. I think I want a new one and figure the latest one would be best.
Tearinitup
VP Code Monkey
posted February 24, 2004 07:31 AM
Ignition Module is going to be a separate unit now so... No such thing as a PCIIIr Usb. But more to the point...The Ign module for the zx12r won't be done in the next month.
pdb1964
posted February 24, 2004 05:53 PM
Richard,
Once you run the PCIII application on the Palm, it will show you a list of maps that you put on your Palm via the computer. You just have to select the one you want and it will download to the PCIII.
Pauly
0.2485888004303 seconds processing time
