posted January 22, 2004 07:29 AM
Lowering Links / Straps What is the effect on the day to day, general handling of the bike once you add lowering links and fork straps to the ZX12? I know they work well at the strip but I was wondering how they work on the road.
posted January 22, 2004 01:52 PM
They suck and are dangerous. Keep it fully suspended on the street.
quote:They suck and are dangerous. Keep it fully suspended on the street.
listen to this man! even if he seems to fuk dogs, he's giving good advice. Strapping on the street is a receipe for disaster. Lowering, Fine.
For nearly 3 years now, I've been running with the middle hole on Muzzys' lowering link, and down 7/8" on the front w/o any problems. However, if my legs were longer, I would leave the rear stock, and maybe drop the front a bit...
posted January 22, 2004 07:37 PM
Edited By: JUNGLE JOE on 22 Jan 2004 19:38
YEA WHATS UP terrass604 ? I HAVE ADJUSTABLE LINKS AND MY TRIPPLE CLAMP IS LOWERED 1.25" AND I RUN (SCHNITZ) LOWERING STRAPS ON MY SLV.01' ZX12R IRUN LIKE THIS ALL DAY AND NIGHT WITH NO PROBLEMS I HAVE INSTALLED THEM CORRECTLY ON 4 OTHER 1200'S AND 13'S U MUST BE CERTAIN THERE IS NO TENSION ON THE STRAPS FOR STREET RIDING (turning) MADKAWRACING -----9.800@145.25MPH
posted January 23, 2004 03:47 AM
You shouldnt run a strap on the street.... PERIOD. It severly limits the travel of your suspension.
You may want to pony up the $80 extra for the adjustable turnbuckle style lowering links. With a 9/16" wrench you can lower the bike at the strip in minutes.
The fixed links are ok... if your ride height is where you want it.
posted January 23, 2004 09:40 AM
yeah, running 'strapped' on the street is a HUGE no no. Now, if it's bolted on and very loose, ok, but not cinched down. I've seen a friend go down because of that and a nasty bump in the road. No suspension movement.
That being said, if you lower the front by sliding the forks up the triple tree clamps, then I'm all for it. I've done it on 3 bikes over the past several years and as long as you pay close attention to the bike's 'rake' and don't bring it too close to the ground, you're ok. Riding 2-up becomes a problem though unless your roads are perfectly baby-butt smooth.
posted January 23, 2004 07:59 PM
YEA HEY WHATS UP ? U GUYS HAVE REALLY GOOD ADVICE, I HAVE CHECKED SUSPENSION TRAVEL UP FRONT AND HAVE FOUND IT TO BE FREE OF ANY BINDING ON 00'S AND 01',02',03', AND ALL BUSA'S NO 1 HAS HAD A BAD SCENE EVEN WITH THEM CINCHED DOWN ! 1 OF MY TEST AFTER INSTALING A FRONT SUSPENSION STRAP SYSTEM IS RANGE OF MOVEMENT AND EASE OF MOVEMENT AS WELL AS OVER-ALL EXTENSION I DO HAVE A PROBLEM WITH THE USE OF FIXED POSITION BOG BONES FOR THE REAR SUSPENSION THEY R MORE WORK TO CHANGE TO DIFF. HEIGHT'S BUT IF THATS WHAT SOME 1 WANT'S 2 USE GOOD FOR THEM. I VERY RARELY ADJUST MY REAR SUSP. IT IS PREMO WHERE IT IS FOR MY HEIGHT AND RIDDING STYLE,BUT AT THE TRACK OUT COME'S THE 2 9/16TH WRENCHES NO NEED FOR A LOT OF TRAVEL AT THIS EVENT! STAY STRAPED. MADKAW RACING--9.800@145.25MPH
posted January 24, 2004 09:07 AM
Jungle Joe, what Dave means is that it's kind of annoying when people type in all caps. You can do what you want, but after a while people just start ignoring your posts.
posted January 24, 2004 09:11 AM
Oh, as for the lowering links and straps, it's ok to lower your bike with the links, but just as you understand that you ground clearance is not going to be there. So, if you're just a coffee shop poser, then it should be OK. But, if you like to ride the twisties aggressively, you're gonna be scraping stuff on a regular basis. And, regarding the strap, don't be lazy, just take it off. It's one freakin bolt on each side of the bike.
posted January 24, 2004 10:09 PM
Yea ok guys once again u really have good advice! I did not know about shouting so thanx for the 411 its all good. I'm glad KAWASAKI put the oil plug guard on the pan or else mine would have been ripped off a long time ago now it's just a very low profile hex head bolt! oh yea check this I service and sometimes completetly rebuild my clutch after every ride always! no matter what. MADKAW RACING
posted January 25, 2004 06:12 AM
I always just moved the forks up in the triple tree to lower it, and used the strap to keep the forks from fully extending at the strip at the launch. Are some of you guys pulling the front end down with the strap? Oof, not much suspension action at all, that way, right? Definately not what I'd ride on the street.
posted February 07, 2004 10:59 PM
they are right on the street no straps you can have them on there but leave them loose, plus i have my bike on the last setting on the link and a 1inch drop in the front. well on a nice road it is really nice but on a bad one , omg you should see the bottom of my fairing, and no to good with speed bumbs at all
posted February 08, 2004 07:27 AM
I just got the Muzzys lowering links...
Anyone know what the spec is for each hole? I want to know if the highest position is more, or less, height then stock?
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
posted February 08, 2004 11:02 AM
I have adjustables on the rear and I had my internals cut 2" for the front shocks. Therefor there is not the ugly look of my shocks sticking out of the top of my triple tree.
I won third place once! Does that count?
