Race Tech Suspension
Techmounts
Cyber tip line
T&J Synthetics - AMSOIL
FEATURED NEWS
American Honda Announces Four More 2010 Models
2009-09-04 01:04
Honda has released four more 2010 models covering the sport, standard, and cruiser sectors. The core of the sport line get small updates with the CBR600RR just getting one new color schemes, and the CBR1000RR getting the same plus a few other small improvements. A new beginner/standard bike arrives in the form of the NT700V, and lightweight cruisers get a new Shadow Phantom. Images and full details follow...
2010 Honda NT700V
2010 Honda Shadow Phantom
2010 Honda CBR1000RR
2010 Honda CBR600RR
2010 Honda NT700V
More NT700V pics below
If you're looking for a light touring machine that's fun, easy to ride and ready to carry you to work and play seven days a week, look no farther than the new NT700V. Fully outfitted and ready to roll, the NT700V can turn your daily commute into riding bliss and then carry you off on that weekend adventure. With full fairing, interlinked saddlebags, a strong 680cc V-twin engine and more, the NT700V is ready for any journey you can dream up.
- Powerful four-valve 680cc liquid-cooled V-twin engine for strong performance and economical operation.
- Programmed Fuel Injection (PGM-FI) delivers excellent throttle response over a wide range of throttle settings and riding conditions.
- Combined Braking System (CBS) with a triple-disc brake system plus the option of ABS for confident braking in varying conditions.
- Large-capacity saddlebags feature a pass-through space between the two sides to facilitate packing of longer items and provide additional carrying capacity.
- Five-position windscreen can be set at the preferred height.
- Convenient remote adjuster for rear shock spring preload adjustment facilitates changes in rear suspension settings.
- Standard model is available in Metallic Red and Metallic Silver colors. ABS model is available in Metallic Silver color only.
Honda Genuine Accessories
- Top Box, 45L Red and Silver, Inner Bag-Trunk, Lower Top Box Pad, Fairing Wind Deflector Set, Knee Pad Set, Heated Grips, DC Socket, Tank Pad, Outdoor Cycle Cover.
Model: NT700V / NT700VA ABS
Engine Type: 680cc liquid-cooled 52° V-twin
Bore and Stroke: 81mm x 66mm
Compression Ratio: 10.0:1
Valve Train: SOHC; four valves per cylinder
Induction: PGM-FI with automatic enrichment circuit, 40mm throttle bodies and 12-hole injectors
Ignition: Digital transistorized with electronic advance
Transmission: Five-speed
Suspension Front: 41mm telescopic fork; 4.5 inches travel
Rear: Single shock with spring preload adjustability; 4.8 inches travel
Brakes Front: Dual full-floating 296mm discs with CBS three-piston calipers
Rear: Single 276mm disc with CBS three-piston caliper; Optional ABS
Tires Front: 120/70 ZR17 radial
Rear: 150/70 ZR17 radial
Wheelbase: 58.1 inches
Rake (Caster Angle): 26.0o 50’
Trail: 115mm (4.5 inches)
Seat Height: 31.7 inches
Fuel Capacity: 5.2 gallons, including 0.9-gallon reserve
Colors: NT700V: Metallic Red, Metallic Silver
NT700VA ABS: Metallic Silver
Curb Weight*: 566 pounds (NT700V) / 571 pounds (NT700VA ABS)
*Includes all standard equipment, required fluids and full tank of fuel- ready to ride.
Meets current California Air Resources Board (CARB) and EPA standards.
©2009 American Honda Motor Co., Inc. All Rights Reserved.
More Shadow Phantom pics below
The Shadow® Phantom delivers on a minimalist concept with a uniquely clean and uncluttered look accented by an extensive blackout treatment, bringing motorcyclists back to the core essence of cool. With a torquey 745cc V-twin engine featuring the convenience of sophisticated Programmed Fuel Injection, the Shadow Phantom brings the joy of back-to-basics riding within reach of just about every rider.
- Minimal bodywork and extensive blacked-out and matte finishes.
- New handlebar shape enhances bobber styling.
- 745cc liquid-cooled V-twin engine produces impressive power over a broad rpm range.
- Programmed Fuel Injection (PGM-FI) incorporates a single 34mm-diameter throttle body.
- Incredibly low 25.7-inch seat height.
- Sturdy and responsive 41mm front fork features large-diameter matte-finished shrouds and large billet-aluminum triple-clamp for a distinctive look, neutral handling and a plush 4.6 inches of wheel travel.
- Dual-shock rear suspension features five-position spring preload adjustability and 3.5 inches of wheel travel for a smooth ride.
- Available in Black.
- Backrest with Pad (two styles: Tall and Low), Rear Carrier, Backrest/Carrier, Boulevard Screen, Custom Leather Seat, Solo Rider Rear Carrier, Cycle Cover, Front Pouch, Synthetic Leather Saddlebags.
Model: VT750C2A
Engine Type: 745cc liquid-cooled 52° V-twin
Bore and Stroke: 79mm x 76mm
Compression ratio: 9.6:1
Valve Train: SOHC; three valves per cylinder
Induction: PGM-FI with automatic enrichment circuit, one 34mm throttle body
Ignition: CD with electronic advance, two spark plugs per cylinder
Transmission: Wide-ratio five-speed
Final Drive: Shaft
Suspension Front: 41mm fork; 4.6 inches travel
Rear: Dual shocks with five-position spring preload adjustability; 3.5 inches travel
Brakes Front: Single 296mm disc with twin-piston caliper
Rear: Drum
Tires Front: 120/90-17
Rear: 160/80-15
Wheelbase: 64.5 inches
Rake (Caster angle): 34o
Trail: 161mm (6.3 inches)
Seat Height: 25.7 inches
Fuel Capacity: 3.9 gallons, including 0.9-gallon reserve
Colors: Black
Curb Weight*: 549 pounds
Meets current EPA standards.
California version meets current California Air Resources Board (CARB) standards and may differ slightly due to emissions equipment.
How do you improve upon the machine rated best by one magazine after the other, a revolutionary literbike that's the lightest, best handling, most compact and highest performing sportbike to be found? Last year we made the CBR1000RR available with our high-tech electronically controlled Combined ABS for the ultimate in sophisticated sportbike braking performance, and the new 2010 model adds engine changes that provide an even smoother power delivery.
New for 2010
- Increased-diameter flywheel for more inertia and improved performance.
- Redesigned license plate stay for easier removal on track days.
- New muffler cover for enhanced appearance.
2010 Honda CBR600RR
EVENTS
<< NOVEMBER >>
M T W T F S S
            1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30
Add your event
COLUMNS
LATEST TOPICS
© 2000-2009 Bikeland Media Inc. All rights reserved.
